Z axis total failure
tmorck
(@tmorck)
Halfway thru a print, the z axis stopped moving.  I shutdown, and tried manually to move the axis.  I can move in X and Y, but not at all in Z.  The PINDA probe appears to be working.  It has its light on, and senses when metal is held up.  I tried a "calibrating Z" first layer calibration.  It homes x and y, but never moves in the z direction.  help!!
i3 MK 3 s, running 3.9.0-3421 firmware
Opublikowany : 28/09/2020 10:31 pm
RE: Z axis total failure
Has the printer ever worked?
Opublikowany : 29/09/2020 12:41 am
tmorck
(@tmorck)
@charles-h13
Yes.  It has been working well.  I’ve printed a lot of items.  It just stopped moving in the z direction.
Opublikowany : 29/09/2020 1:13 am
Is the motor spinning or making any noise?
Opublikowany : 29/09/2020 12:22 pm
tmorck
(@tmorck)
@charles-h13
doesn't appear to.  No motion observed.  no binding noticed.  able to manually turn screws to raise and lower head.
Z value has a "?".  After a time, it goes to calibrating Z, but still no motion.  then locks out.
Attachment removed
Opublikowany : 29/09/2020 1:09 pm
