Soluble support material(s) question
chmax
(@chmax)
 I 'd like to start soluble materials for the contact layer of support structures and having a hard time sorting out what soluble filament(s) to use with what. I use PLA, PETG, PCBlend, and ASA (there is also a roll of ABS still sitting in the shelf but rarely used).
May I kindly ask those that have experience with this to share it here? Thanks in advance.
Best Answer by hyiger:
Posted by: @chmax
For PETG and PLA you can use the opposite as a support material or an interface layer. Example if printing PLA you can use PETG as the support/interface layer and vis versa. They don't stick to each other so can treat both as a "soluble supports". If you need a soluble internal supports then something like PVA will work since it can be dissolved in water.
For ASA and PC Blend, HIPS is the best support material for break-away supports and interface. HIPS can also be dissolved with d-limonene but can damage ASA if you try to soak the part. For PC parts I just dunk the part in d-limonene to dissolve the HIPS, for ASA I peel it off by hand.
Posted : 02/05/2026 9:08 pm
Posted by: @chmax
Posted : 02/05/2026 9:46 pm
_KaszpiR_
(@_kaszpir_)
RE: Soluble support material(s) question
If you go to https://help.prusa3d.com/filament-material-guide ans select Dissolvable and Support Material.tjen you can expand two sections and there should be dedicated articles for given material with more details.
Posted : 02/05/2026 9:57 pm
chmax
(@chmax)
Posted by: @hyiger
Many thanks! Any brand recommendations for HIPS?
Posted : 03/05/2026 12:30 am
chmax
(@chmax)
Thanks. Alas, the info in the table and the linked article do not really cover much beyond using pla and petg as target materials. A new column for all materials indicating the best soluble interface would be a much more useful option...
Posted by: @_kaszpir_
This post was modified 2 months ago by chmax
Posted : 03/05/2026 12:37 am
Posted by: @chmax
Shouldn't really matter. I have a roll of Gizmo Dorks HIPS but any brand will work.
Posted : 03/05/2026 12:44 am
