First check SuperPINDA sensor error
maximusmeridus
(@maximusmeridus)
Hey all,
I've just assembled new Mini+ and I keep running into this issue. The Superpinda sensor lights so the connection is fine. What could be the issue other than replacing it?
SuperPinda Video
This topic was modified před 3 years by maximusmeridus
Napsal : 09/08/2023 9:32 am
maximusmeridus
(@maximusmeridus)
RE: First check SuperPINDA sensor error
Napsal : 09/08/2023 9:48 am
AndrewTerry
(@andrewterry)
If you're certain all connections are correct, might be worth asking the Prusa Support chat - it's available 24/7 via the online store, and (in experience, at least) they're pretty good.
Napsal : 11/08/2023 9:03 am
René
(@rene-3)
This problem can also be caused by the Z axis.
Here is the instruction to fix it.
Napsal : 11/08/2023 11:39 am
mate0+
(@mate0)
Hey, I had the same error,
I tried everything from testing Pinda( https://help.prusa3d.com/article/m-i-n-d-a-superpinda-sensor-testing-mini-mini_134021 ) to correct sensor offset from the table.
And I tried everything but none was successful. Until I contacted support and they claimed that it can be problem with too tight tightening on cable ties. And it works my cable tie around Extruder was too tight.
Napsal : 14/08/2023 9:12 am
maximusmeridus
(@maximusmeridus)
Ok that sort of worked. But not the X-axis calibration test failed. What is causing this failure?
This post was modified před 3 years by maximusmeridus
Napsal : 25/08/2023 9:33 am
