First check SuperPINDA sensor error
maximusmeridus
(@maximusmeridus)
Miembro
Hey all,
I've just assembled new Mini+ and I keep running into this issue. The Superpinda sensor lights so the connection is fine. What could be the issue other than replacing it?
SuperPinda Video
Este debate ha sido modificado el hace 3 years por maximusmeridus
Respondido : 09/08/2023 9:32 am
maximusmeridus
(@maximusmeridus)
Miembro
RE: First check SuperPINDA sensor error
Respondido : 09/08/2023 9:48 am
AndrewTerry
(@andrewterry)
If you're certain all connections are correct, might be worth asking the Prusa Support chat - it's available 24/7 via the online store, and (in experience, at least) they're pretty good.
Respondido : 11/08/2023 9:03 am
René
(@rene-3)
This problem can also be caused by the Z axis.
Here is the instruction to fix it.
Respondido : 11/08/2023 11:39 am
mate0+
(@mate0)
Hey, I had the same error,
I tried everything from testing Pinda( https://help.prusa3d.com/article/m-i-n-d-a-superpinda-sensor-testing-mini-mini_134021 ) to correct sensor offset from the table.
And I tried everything but none was successful. Until I contacted support and they claimed that it can be problem with too tight tightening on cable ties. And it works my cable tie around Extruder was too tight.
Respondido : 14/08/2023 9:12 am
maximusmeridus
(@maximusmeridus)
Miembro
Ok that sort of worked. But not the X-axis calibration test failed. What is causing this failure?
Esta publicación ha sido modificada el hace 3 years por maximusmeridus
Respondido : 25/08/2023 9:33 am
