X axis homing failure
rivka
(@rivka)
See video here (of another person with the same problem)
  https://www.reddit.com/r/prusa3d/s/tl5TrM3AV5
This topic was modified 2 years temu by rivka
Opublikowany : 23/02/2024 6:26 am
cdeutsch
(@cdeutsch)
RE: X axis homing failure
I am having the same problem.  The person who originally posted the video said they had the nylon filament in the hole with the belt.  I moved mine but I'm still having the same issue.
Opublikowany : 18/06/2024 8:57 pm
Antimix
(@antimix)
RISPONDI: X axis homing failure
the MK3.5 does not involve the dismount of the X axes motors, but requires re-cabling the connection to the new motherboard. So I would exclude mechanical problems. I would address on false contact / swapped wires between the X motor cable and the adapter that goes to the motherboard.
It could help if you do a video of your issue.
Regards
Opublikowany : 23/06/2024 7:40 pm
