X axis homing failure
See video here (of another person with the same problem)
https://www.reddit.com/r/prusa3d/s/tl5TrM3AV5
Ce sujet a été modifié il y a 2 years par rivka
Publié : 23/02/2024 6:26 am
RE: X axis homing failure
I am having the same problem. The person who originally posted the video said they had the nylon filament in the hole with the belt. I moved mine but I'm still having the same issue.
Publié : 18/06/2024 8:57 pm
RISPONDI: X axis homing failure
the MK3.5 does not involve the dismount of the X axes motors, but requires re-cabling the connection to the new motherboard. So I would exclude mechanical problems. I would address on false contact / swapped wires between the X motor cable and the adapter that goes to the motherboard.
It could help if you do a video of your issue.
Regards
Publié : 23/06/2024 7:40 pm
