Settings for CarbonX ezpc+cf
Barry A
(@barry-a)
Does anyone have settings for this filament?  CarbonX EZPC+CF by 3DXTech.   The settings for Prusa PC blend CF generate what looks like over extruded results, some stringing and blobs.  Printed at 265 with another set of settings for a different PC+CF, better but still rough.  Printed both .25 and .3 layer height per their recommendation to print at least .25 layer heigh , with diamond tipped .4 nozzle.    Checked with CarbonX 3DXTech; no data there.  Waiting for Prusament PC +CF to be in stock.  Prints beautifully as does the PC natural.  Both out of stock.
Postato : 03/04/2023 7:32 pm
Netpackrat
(@netpackrat)
RE: Settings for CarbonX ezpc+cf
I printed a few parts with this filament last week.  I used a nozzle temp of 280C, and a bed temp of 100C for the first layer, increasing to 110C for subsequent layers.  I used an Undertaker 0.4mm tungsten carbide nozzle from West3d and 0.2mm layer height.  Doubtless these settings could be improved upon but they worked for me.
https://www.printables.com/@Netpackrat/models
Postato : 04/04/2023 1:19 am
Barry A
(@barry-a)
Thank you for the reply.  Did you use the Prusa Slicer settings for PC?  My .2mm layer  were not very good.  Recommended .25, even .3 still had some blobs and stringing.  I'm wondering if you changed flow or extrusion or anything else.
Postato : 04/04/2023 12:36 pm
 Utente
We started printing with it since the prusament PC+CF is never in stock. We tried printing at 285 nozzle (tungsten carbide) 110 bed. At 285 on the nozzle there was a substantial build up on the nozzle for a 27h print and the overall finish was ruff. Now we print at 275, the build up is not a problem but the overall finish stay a little ruff compared to the prusament pc cf. At 275 on the nozzle the layer bounding is great, we broke the printed parts and there was no delamination. We use 0.99 extrusion multiplier with prusaslicer 2.6.
what we struggle with is the fact that our part once released are a little warped. By comparison we have zero warping with prusament pc cf. We use Satin sheet cleaned with 99% IPA, brim 5mm, slowed speed for first layer and not much draft from ambient air.
We are still tweaking the parameters, I'll keep posting here if we get result comparable result to prusament PC CF.
Postato : 04/04/2023 2:40 pm
Barry A
(@barry-a)
Thanks very much for taking the time to reply.   Prusament PC_Cf prints so nicely, the CarbonX is quite rough by comparison.  It is not workable for me unless I can smooth it out more. Eagerly awaiting a new batch of Prusament PC-CF.  I don't think they can make too much, the natural is also a wonderful filament; also out of stock.  That's my only complaint with Prusa, love the printer.  The MK4 sounds like another step forward.
As an aside, I've very good results printing Prusament PC_Cf and PC natural on the PEI sheet with MagiGoo for PC.  Easy to clean the sheet with IPA, nice release
Questo post è stato modificato 3 years fa 2 tempo da Barry A
Postato : 04/04/2023 8:32 pm
Netpackrat
(@netpackrat)
Posted by: @barry-a-2
I started with the PC settings in Prusaslicer, changed the temps to what I mentioned above.  I hadn't realized they recommended a thicker layer height.  I did indeed have some blobbing at the nozzle, which mostly went away once I got the new TC nozzle adjusted (I had my Z offset too low initially so it was dragging a little), but not completely.  I only had a few small parts to print; nothing like the 27 hour print that was mentioned.  I needed sheet stops for my Voron 2.4 and since they are in contact with the heatbed, I wanted something with higher temp resistance than the ASA the rest of the printer uses.  While I was at it, I printed a couple of new cooling fan shrouds for my Bear.  There is a slightly rougher surface texture to the parts which I assume is due to the CF.  I have no experience with any other PC or CF filament so I have nothing to compare with.
Postato : 07/04/2023 8:23 pm
CW
 CW
(@cw-4)
TL;DR
Copy and paste the code block for a usable filament profile.
Tips for success with this filament:
  • Dry it first if you can (4-6 hrs @ 80°C; it makes a big difference with this material)
  • Prints well with .4mm or .6mm HF Obxidian nozzles
  • Magigoo PC on the satin build sheet
  • Enclosure closed
I know this thread is over 2 years old but it comes up in search results for this filament. I really like this filament. It works great for mechanical parts and it stays rigid instead of getting slightly soft like Markforged Onyx does over time (PA6-CF; a great material but gets less stiff in humid environments). I've been storing the CarbonX in a sealed dry box with several large desiccant packs and it's still printing well a couple months after drying it. It oozes a good amount when using a .4mm nozzle, but doesn't seem to as much with a .6mm nozzle.
CarbonX ezPC+CF Profile for PrusaSlicer
# generated by PrusaSlicer 2.9.3-beta1 on 2025-10-15 at 16:13:41 UTC
bed_temperature = 95
bridge_fan_speed = 30
chamber_minimal_temperature = 0
chamber_temperature = 0
compatible_printers =
compatible_printers_condition = nozzle_diameter[0]>=0.4 or nozzle_diameter[0]>=0.6 and nozzle_diameter[0]!=0.8 and printer_notes=~/.*XL.*/
compatible_prints =
compatible_prints_condition =
cooling = 1
cooling_perimeter_transition_distance = 0
cooling_slowdown_logic = uniform_cooling
custom_parameters_filament = ""
disable_fan_first_layers = 4
enable_dynamic_fan_speeds = 0
end_filament_gcode = "; Filament-specific end gcode"
extrusion_multiplier = 1
fan_always_on = 0
fan_below_layer_time = 10
filament_abrasive = 1
filament_colour = #525252
filament_cooling_final_speed = 2.5
filament_cooling_initial_speed = 5
filament_cooling_moves = 3
filament_cost = 117.33
filament_density = 1.36
filament_deretract_speed = nil
filament_diameter = 1.75
filament_infill_max_crossing_speed = 50
filament_infill_max_speed = 100
filament_load_time = 10.5
filament_loading_speed = 10
filament_loading_speed_start = 50
filament_max_volumetric_speed = 9
filament_minimal_purge_on_wipe_tower = 35
filament_multitool_ramming = 1
filament_multitool_ramming_flow = 40
filament_multitool_ramming_volume = 10
filament_notes = ""
filament_purge_multiplier = 100%
filament_ramming_parameters = "250 100 42.4194 42.4194 42.4194 42.4194 42.4194| 0.05 42.4387 0.45 42.4387 0.95 42.4387 1.45 42.4387 1.95 42.4387 2.45 42.4387 2.95 42.4387 3.45 42.4387 3.95 42.4387 4.45 42.4387 4.95 42.4387"
filament_retract_before_travel = nil
filament_retract_before_wipe = nil
filament_retract_layer_change = nil
filament_retract_length = 10
filament_retract_length_toolchange = 20
filament_retract_lift = nil
filament_retract_lift_above = nil
filament_retract_lift_below = nil
filament_retract_restart_extra = nil
filament_retract_restart_extra_toolchange = nil
filament_retract_speed = nil
filament_seam_gap_distance = nil
filament_settings_id = ""
filament_shrinkage_compensation_xy = 0%
filament_shrinkage_compensation_z = 0%
filament_soluble = 0
filament_spool_weight = 193
filament_stamping_distance = 45
filament_stamping_loading_speed = 26.5
filament_toolchange_delay = 0
filament_travel_lift_before_obstacle = nil
filament_travel_max_lift = 1.5
filament_travel_ramping_lift = 1
filament_travel_slope = 1
filament_type = PC
filament_unload_time = 8.5
filament_unloading_speed = 100
filament_unloading_speed_start = 100
filament_vendor = Prusa Polymers
filament_wipe = nil
first_layer_bed_temperature = 95
first_layer_temperature = 275
full_fan_speed_layer = 0
idle_temperature = 150
inherits = Prusament PC Blend Carbon Fiber @XL
max_fan_speed = 20
min_fan_speed = 20
min_print_speed = 15
overhang_fan_speed_0 = 0
overhang_fan_speed_1 = 0
overhang_fan_speed_2 = 0
overhang_fan_speed_3 = 0
slowdown_below_layer_time = 20
start_filament_gcode = "{if printer_notes!~/.*(MK4IS|XLIS|MK4S|MK3.9S|COREONE).*/}\nM900 K{if nozzle_diameter[filament_extruder_id]==0.4}0.07{elsif nozzle_diameter[filament_extruder_id]==0.3}0.09{elsif nozzle_diameter[filament_extruder_id]==0.35}0.08{elsif nozzle_diameter[filament_extruder_id]==0.6}0.04{elsif nozzle_diameter[filament_extruder_id]==0.5}0.05{elsif nozzle_diameter[filament_extruder_id]==0.8}0.02{else}0{endif} ; Legacy LA\n{else}\nM572 S{if nozzle_diameter[filament_extruder_id]==0.4}0.05{elsif nozzle_diameter[filament_extruder_id]==0.5}0.035{elsif nozzle_diameter[filament_extruder_id]==0.6}0.025{elsif nozzle_diameter[filament_extruder_id]==0.8}0.016{elsif nozzle_diameter[filament_extruder_id]==0.25}0.14{elsif nozzle_diameter[filament_extruder_id]==0.3}0.09{else}0{endif} ; Pressure advance\n{endif}\n\nM142 S45 ; set heatbreak target temp"
temperature = 275
Postato : 16/10/2025 2:01 pm
thenoname
(@thenoname)
Utenti
Thank you so much for posting that profile!
Postato : 31/12/2025 1:17 am
