Slic3r PE print information
Prior to ordering the printer I have been looking at the Slic3r PE software. I cant seem to find any information on material usage or print time once the model has been sliced, is this information available and if so where? Thank you!
Questa discussione è stata modificata 7 years fa da Der773
Postato : 12/05/2019 10:12 am
RE: Slic3r PE print information
After you "slice now" do an "export G-code". It will show material used and estimated printing time after it saves the file.
Edit to add: And it's in the window, bottom right.
Postato : 13/05/2019 2:19 am
Topic starter
answered:
Thank you both!
Postato : 13/05/2019 4:28 am
