Slic3r PE print information
Der773
(@der773)
Prior to ordering the printer I have been looking at the Slic3r PE software.  I cant seem to find any information on material usage or print time once the model has been sliced, is this information available and if so where?  Thank you!
This topic was modified před 7 years by Der773
Napsal : 12/05/2019 10:12 am
Mj
 Mj
(@mj-2)
RE: Slic3r PE print information
After you "slice now" do an "export G-code".  It will show material used and estimated printing time after it saves the file.
Edit to add: And it's in the window, bottom right.
Napsal : 13/05/2019 2:19 am
And the next release will have material after slicing. Won't have to create a gcode any more.
Napsal : 13/05/2019 4:06 am
Der773
(@der773)
Thank you both!
Napsal : 13/05/2019 4:28 am
