Slic3r PE print information
Prior to ordering the printer I have been looking at the Slic3r PE software. I cant seem to find any information on material usage or print time once the model has been sliced, is this information available and if so where? Thank you!
Este debate ha sido modificado el hace 7 years por Der773
Respondido : 12/05/2019 10:12 am
RE: Slic3r PE print information
After you "slice now" do an "export G-code". It will show material used and estimated printing time after it saves the file.
Edit to add: And it's in the window, bottom right.
Respondido : 13/05/2019 2:19 am
Topic starter
answered:
Thank you both!
Respondido : 13/05/2019 4:28 am
