Slic3r PE print information
Der773
(@der773)
Prior to ordering the printer I have been looking at the Slic3r PE software.  I cant seem to find any information on material usage or print time once the model has been sliced, is this information available and if so where?  Thank you!
Questa discussione è stata modificata 7 years fa da Der773
Postato : 12/05/2019 10:12 am
Mj
 Mj
(@mj-2)
RE: Slic3r PE print information
After you "slice now" do an "export G-code".  It will show material used and estimated printing time after it saves the file.
Edit to add: And it's in the window, bottom right.
Postato : 13/05/2019 2:19 am
And the next release will have material after slicing. Won't have to create a gcode any more.
Postato : 13/05/2019 4:06 am
Der773
(@der773)
Thank you both!
Postato : 13/05/2019 4:28 am
