General question about steel sheet texture
Fnord Prefect
(@fnord-prefect)
Hi there,
I have a textured steel sheet that I like very much, but I noticed that the texture is noticeably coarser than the one that has apparently been used to print my printer's parts. Are there different kinds of textured sheets?
Cheers
Gert
Postato : 16/07/2020 9:29 am
Walleye
(@walleye)
RE: General question about steel sheet texture
Yep. My textured sheet is a 4King sheet. It has a pretty fine texture to it.
Postato : 16/07/2020 8:59 pm
jsw
 jsw
(@jsw)
There was chatter some time ago that they switched manufacturers of the textured sheets, apparently due to quality control.
Postato : 16/07/2020 10:44 pm
Fnord Prefect
(@fnord-prefect)
@dalee1002000
Yeah, I have a "thekkiinngg v2" sheet that I imagine is similar to yours(?). (Couldn't wait for the Prusa sheets to become available back then). Unfortunately it seems to be not perfectly even - small prints work fine, but large prints suffer from differing first level thickness, as if the coating on the metal sheet has a varying thickness. It's still nice and I like the texture for some applications, but quality-wise the Prusa sheet that I have is clearly superior.
Regarding the grain of the surface, my printer's original parts seem to be somewhere between my Prusa sheet and the thekkiinngg sheet.
Questo post è stato modificato 6 years fa da Fnord Prefect
Postato : 23/07/2020 3:21 pm
Fnord Prefect
(@fnord-prefect)
@jsw
I remember that - it sounded like it was quite a pain for Prusa to get a reliable supplier/process.
Would be interesting to know if the printed parts of newer printers have the coarser surface texture too, or if they use different sheets in-house.
Postato : 23/07/2020 3:25 pm
Walleye
(@walleye)
Posted by: @gert-m
@dalee1002000
I  bought mine 2 months ago. I've not had any issue with it and I have printed some larger PETG stuff on it without issue. I suspect a QC issue maybe responsible for your problems. 3rd tier products can be iffy for quality sometimes. I might have just gotten luckier than you.
Postato : 24/07/2020 5:39 pm
