I put a Revo Nozzle on my Nextruder. Here's how.
Thomas Lovén
(@thomas-loven)
It was much easier than I ever dared to hope, but darned scary...
Here's the full description: https://github.com/thomasloven/nextrevo-mod
It's not a guide. I do not take any responsibility for anything if you decide to try this yourself.
Publié : 06/10/2023 9:01 pm
5 personnes ont aimé
MysticGringo
(@mysticgringo)
RE: I put a Revo Nozzle on my Nextruder. Here's how.
Awesome! I figured it wouldn't be that difficult and I bet that there's an official upgrade to REVO where they send you a different heatsink. I am going to order parts and see if I can do this too. I am in the same boat as you, had a complete set of REVO nozzles and many spares when MK4 was announced.
Publié : 10/10/2023 1:47 pm
Rambo
(@rambo)
I exchanged some emails with E3D and they have (currently) no plans for making a Revo compatible heatsink so modifying ours is the way to go. This is what I did:
  • Buy a new heatsink (so I had a fallback in case things went badly) and V6 adapter
  • superglue the v6 adapter into the heatsink (should probably have first scuffed both the copper and the heatsink a bit and used heat-conductive epoxy)
  • Use dremel cutting disk to cut the brass threaded bit off
  • use 2.1mm (? AFAIRecall, doublecheck yourself) drill to depth of the revo nozzle when installed so it fits snugly agains the stainless steel pipe of the V6 adapter
  • use 3.3mm drill to prepare the hole for tapping.
  • Tap M4 hole. here the remaining very thin bit of copper started to give me trouble, in the end it just started to rotate freely and I had to pull it out so I ended up in effect with same solution as OP.
My original even fancier plan was to ream the hole and put a bit larger bit of copper by shrink-fit there so I could make proper threads into the copper too but got impatient.
For the click-mate connector I got some ready made cable assemblies from Digikey, then dismantled the original thermistor connector, to keep the crimped bits, cut the cable assembly to length and soldered on the crimped bits and put heatshrink insulation tube over it.
Ce message a été modifié il y a 2 years par Rambo
Publié : 14/11/2023 8:57 am
Rambo
(@rambo)
Forgot the link https://www.digikey.fi/fi/products/detail/molex/0151350206/6830168
Publié : 14/11/2023 9:03 am
Rambo
(@rambo)
If enough people have too much money and not enough courage/trust in their DIY skills I could setup the CNC mill at the local hacklab to do a batch of these but it would be probably be around 120-150EUR/heatsink + shipping to cover my costs (a fact of life is that *at least* one of the heatsink+adapter combos will end up in the box-of-shame because of some mistake) and get me some beers for the trouble.
Publié : 14/11/2023 9:12 am
Thomas Lovén
(@thomas-loven)
I also considered puting something into the hole to get more threads, but thought it would be too thin unless it was solidly brazed or something.
Careful with that idea, though. I understand E3d are rather... protective... about the Revo design and compatibility.
Publié : 14/11/2023 10:52 am
Thomas Lovén
(@thomas-loven)
To celebrate the release of the MK4 Nozzle Replacement Tool, here's a 1-up.
(I hope the video works... otherwise it's here)
Publié : 13/03/2024 8:46 pm
Clamikra
(@clamikra)
Very nice result! But I will keep on using my revo nozzles in the „old MK3.5“ for now and use the new system in the MK4 nextruder. I am afraid damaging my new shiny MK4. Perhaps when someone jumps on this idea and sells an „Upgrade kit MK4 to Revo6“. I definitely would pay for this some money if it works (and the print results are equal.
Publié : 23/03/2024 1:46 am
Onno
 Onno
(@onno)
Someone pointed me to your project. It's a nice starting point for exploring the possibilities of mounting a Revo to a MK4 or Core ONE. However, when looking at the drawings, I do see a potential problem in how the nozzle is mounted. There is relatively little surface area between the thread of the nozzle and the cooling body. This limits heat transfer and provides comparatively little grip for the nozzle.
While discussing the option for mounting a Revo to the Core ONE, the person who pointed me to this project also did some digging for me for creating a fanmount body with a CNC. Somebody already modeled the body for the MK4, but not with sufficient detail to enable further work on this. Does anyone have a more accurate 3D scan of the part which could act as a good starting point for creating a new part on a CNC?
Also, does anyone know how to recalibrate the load sensor for such a mod?
Publié : 28/05/2025 11:30 pm
Rambo
(@rambo)
Grip is not an issue, the heat transfer can be. I've had some clogging with nozzles smaller than 0.4mm, probably because of the filament heating up too much in the "cold" part.
Anyway it's been running well enough that I still haven't gotten around to making the proper version where I ream a larger hole, shrink-fit a copper plug and then do the threads.
Publié : 29/05/2025 7:35 am
Thomas Lovén
(@thomas-loven)
I've never had any issues with grip either. Except in one single instance when I didn't tighten the nozzle enough. Then it slipped out a tiny bit, which ruined the first layer.
The heat transfer has been a concern of mine too. So far I haven't had any issues even on rather long running prints, but I have considered trying to "fill the void" by e.g. wrapping the threads with something. Like steel wool but copper, or so...
Publié : 29/05/2025 8:41 am
