Stacking LACK IKEA Table Enclosures..
Jake
 Jake
(@jake-2)
A bit of a weird question (and sorry if it’s posted in the wrong place) but I was just wondering if anyone here had any experience stacking IKEA Lack Enclosures?
I have three in total but I’m tentative to stack them all vertically. It would be a godsend if we could, to save space, and I’m quite sure the structure of the enclosures would not cause any issues, however I’m concerned about the amount of accumulated vibration from three printers running simultaneously potentially jeopardising the quality of prints.
I have added the squash ball anti-vibration feet mod to each printer to try to best mitigate this but I thought I’d ask here for any advice first -
Postato : 26/12/2023 6:17 pm
Jake
 Jake
(@jake-2)
RE: Stacking LACK IKEA Table Enclosures..
Apologies - I should add that the printers are all Prusa Mini+
Happy New Year to all⭐️
Postato : 27/12/2023 12:26 pm
_KaszpiR_
(@_kaszpir_)
It's more important to add concrete slabs between printer and the base it stands on ( in that case it would be a Lack table).
Just try it?
Postato : 27/12/2023 11:53 pm
1 persone hanno apprezzato
mixer3d
(@mixer3d)
Hi, if you have firmware at least in 5.1.x, but probably better to have the latest one, you can download BonkersBenchy_PLA_MINI_IS_16m.gcode , from prusa github account, and print on your printer, for best experience top left one will be the best 🙂 [and try two  printers at once too] so you will see the mechanical limits, and maximum accelerations those printers can achieve, and how wobby the ikea lack table is. And then probably you will want to add something to make the tables more sturdy. But it can work that way anyway 😉 Also you will find that the surface of the table is great speaker, so if you are concerned about noise you can add rubber mat which cut the noise a lot. And in your configuration looks like that if you will want to print Z layer up to 180mm the top ptfe tube and cables will scratch the table, and probably it can even degrade printing tall objects... Still, for small models it's not probably the issue. Good stable tables has supports, most of the time parallel lines under the base plate, but triangles are very good, maybe less practical for daily used tables, but for device support should be fine, when you add them, you can limit linear acceleration a lot, in my test based on the model from 2-10 times, and with additional mat it made the printers much more bearable to listen to 😉
Postato : 29/12/2023 1:15 pm
Jake
 Jake
(@jake-2)
Hi all, Happy New Year and sorry for the late reply
Posted by: @_kaszpir_
Just try it?
Thanks for the advice, I've bought some concrete slabs, cut them to size and painted them (my local retailer advised this to seal the dust). Just finished setting up the rig so planning to give it a test run soon.
Posted by: @mixer3d
Wow thanks for the advice! That's super helpful - please could you let me know where I can find the BonkersBenchy files? I did have a look on this page on GitHub but I'm not too familiar with it. I'm only asking because one of my printers is set up with PETG while the other two print PLA
Postato : 15/01/2024 6:24 pm
mixer3d
(@mixer3d)
hi, in my presious message you have a link, just click it 😉 it's for PLA
Postato : 15/01/2024 7:14 pm
_KaszpiR_
(@_kaszpir_)
there is no SwoleBenchy for PETG, only PLA, but you could get the .gcode and edit it with text editor and bump bed temperature to 85C and hotend temperature to 240C (something like 4 lines in total) and you should be good to go (probably 😀 )
Postato : 15/01/2024 8:46 pm
Jake
 Jake
(@jake-2)
Ah thank you for clarifying 😀 !
Just before I break anything, the relevant part of the gcode for the PLA benchy looks like this:
M104 S170 ; set extruder temp for bed leveling
M140 S60 ; set bed temp
M109 R170 ; wait for bed leveling temp
M190 S60 ; wait for bed temp
M569 S1 X Y ; set stealthchop for X Y
M204 T1250 ; set travel acceleration
G28 ; home all without mesh bed level
G29 ; mesh bed leveling
M104 S220 ; set extruder temp
G92 E0
G1 Y-2 X179 F2400
G1 Z3 F720
M109 S220 ; wait for extruder temp
Presumably I just need to make these changes:
M140 S85 ; set bed temp
M190 S85 ; wait for bed temp
M104 S240 ; set extruder temp
M109 S240 ; wait for extruder temp
Postato : 16/01/2024 8:59 am
_KaszpiR_
(@_kaszpir_)
Yes
/ Me runs away
Postato : 16/01/2024 9:05 am
mixer3d
(@mixer3d)
maybe to be on the safe side just run the provided gcode on PLA ready printer? at least you will understand what this bonxersbenchy is 😉  still it's printer acceleration and vibrations of the table, PETG is different than PLA
Postato : 16/01/2024 9:10 am
mixer3d
(@mixer3d)
ah, and i realized that probably we are talking about two different flies, i don't know the 'SwoleBenchy' but the file i'm reffering to is 'BonkersBenchy' and was released together with 5.1.0-alpha1 firmware for MINI, and you have to use IS to print it:
https://github.com/prusa3d/Prusa-Firmware-Buddy/releases/tag/v5.1.0-alpha1
Postato : 16/01/2024 8:08 pm
_KaszpiR_
(@_kaszpir_)
hm sorry for confusion,  I meant BonkersBenchy in my posts, not SwoleBenchy...
Postato : 16/01/2024 11:17 pm
Jake
 Jake
(@jake-2)
Sorry to resurrect but I just wanted to post an update that three enclosures stacked produced very little vibration / side-to-side movement.. or at least, not enough to affect print quality when all three printers are running.
Very much recommend a setup like this.. it was a godsend when I was starting out and had a lot of printing needs but not much space for printers.
Postato : 01/08/2025 2:32 pm
_KaszpiR_
(@_kaszpir_)
Could you show some pictures with details of the assembly, printer placement/slabs, hole placement for filament or cables etc?
Postato : 01/08/2025 7:50 pm
Jake
 Jake
(@jake-2)
Sure thing! I can't take credit for the build, and you're probably more likely to get the answers you're looking for from this page.
This is also a fantastic video tutorial which shows the full assembly.
Nonetheless I'll share the few photos that I've got and some relevant points. The enclosure and printers are currently for sale and semi-packed up as I've scaled up production and therefore had to upgrade to some better printers.
• Printers and slabs were placed central in the enclosure. One concrete slab per enclosure seemed to the trick and they are around 16mm thick. I also spray painted them to seal any dust.
• I cut a small inlet into the LACK tables at the back for cables to pass through. Doesn't look the most aesthetic but it does the job and it's out of sight.
• For filament, I opted this mod for Prusa Mini's which allows you to save space within each individual enclosure by mounting the filament spool onto the printer and forgoing the standard Prusa Mini filament mount/stand. There are many iterations of this, as well as alternative solutions, including some which feed filament into the enclosure through PTFE tubes but this was too much hassle for me and I didn't want to have to worry about a keep-dry solution for filament outside of the enclosure.
playlist
Postato : 01/08/2025 9:32 pm
_KaszpiR_
(@_kaszpir_)
It looks so compact and clean 😀
I've got single printer with original enclosure for a Mini and it's quite messy because you can see every bit of snipped filament inside of it. Also because it is black it needs a bit more light to make it bright - your white Lack tables look so much better 🙂
Postato : 02/08/2025 7:11 am
Jake
 Jake
(@jake-2)
Thanks so much! I highly recommend looking into this type of enclosure if it interests you - it was pretty cheap to put together and worked surprisingly well. I had the perspex custom ordered and cut so that was probably the most costly part but in total it probably cost around £60 including the tables which people seem to pretty much give away for free on Facebook Marketplace.
Postato : 02/08/2025 7:25 am
mixer3d
(@mixer3d)
Great, but seems that in the max Z position there is not enough space for ptfe tube, so it will bend and create more friction, still it's not the issue for smaller objects. But personally since i print also taller objects i used extensions for the table legs to have enough space even with max size in Z axis.
Postato : 02/08/2025 12:59 pm
Jake
 Jake
(@jake-2)
Posted by: @mixer3d
This is a very good point! Apologies, I should have mentioned before that I only printed small objects (maximum height 15cm) with my Prusa Mini's so this was never an obstacle for me, but those wanting this kind of set up to print tall objects should definitely be mindful of the height limitations.
Postato : 02/08/2025 1:04 pm
