Print failure at inner circle perimeter
y arakawa
(@y-arakawa)
I have an issue with printing failure at the inner circle perimeter.
The layer goes straight instead of sticking to the proper position.
As a reference, I have attached an image of that.
How do I solve this issue to have settings on Prusaslicer?
And what name is this issue? I can not find solutions for it.
My basic settings are below
  • Prusa MK3S+ with MMU2S
  • Filament EONO PETG RED
  • Nozzle 0.8mm
  • Temperature 240°C
  • Bed 80°C
And tell me the information you need to solve this issue.
Postato : 27/07/2022 4:31 am
Utenti
RE: Print failure at inner circle perimeter
Are you sure your first layer calibration is dead on?  Can you post an image of that square?
Postato : 27/07/2022 10:27 am
I find this happens more easily with PETG than PLA. As cwbullet said, make sure your Live Z is spot on. Also, from the looks of it, I'd give that steel sheet a good scrub with hot water and fragrant-free dish washing soap.
Postato : 27/07/2022 10:38 am
y arakawa
(@y-arakawa)
@cwbullet : Do you mean this object after calibration?
Questo post è stato modificato 4 years fa 3 tempo da y arakawa
Postato : 27/07/2022 11:38 am
y arakawa
(@y-arakawa)
@fuchsr : Thank you for your advice. I will do your suggestion. Do you have any other possible solution for this issue?
Postato : 27/07/2022 11:42 am
y arakawa
(@y-arakawa)
 As a reference, could someone check my settings about speed and extrusion width?
Postato : 27/07/2022 11:47 am
y arakawa
(@y-arakawa)
I got a good print.
I observed the preview of g-code and the printing process.
I found it seemed the speed is too high to stick the new layer on the old one.
I changed the slicer settings of Perimeters from 60mm/s to 30mm/s.
Postato : 31/07/2022 11:18 pm
Good to hear! It's always a better learning experience to come up with the solution yourself.
Postato : 01/08/2022 12:02 am
1 persone hanno apprezzato
