Next Coordinates Placeholders
Pasubio
(@pasubio)
Hi all,
in Simplify3D I found very useful using the following command as last instructions in the Start Gcode Script:
G1 X[next_position_x] Y[next_position_y] Z{EVAL "[next_position_z]+3"}
This command permit to first reach the print start position, and then to lower the nozzle (or raise the bed) to start the print. This behaviour allow a safer nozzle travel from the purge/clean position to the print position, achieving also other benefits during tool change operations.
In Prusa Slicer one can use a similar instructions, for example:
G1 X[first_layer_print_min_0] Y[first_layer_print_min_1] Z{first_layer_height + 2.0}
Anyway these coordinates are about the rectangular print area that cointain the objects, so using that command will lead to leave a spot of polymer just outside the real print.
Do you have any solutions?
The need for these missing placeholders has been pointed out also here:
https://github.com/prusa3d/PrusaSlicer/issues/1670
Opublikowany : 06/10/2021 6:59 am
