MK4 Profile not in PrusaSlicer 2.5.2
Just received my pair of MK4s today and installed PrusaSlicer 2.5.2. When i go into the Configuration Wizard i don't see the MK4 as an option. Where do i go to get the latest MK4 profile for PrusaSlicer?
RE: MK4 Profile not in PrusaSlicer 2.5.2
Hi. I had same problem. Prusa support helped me track down solution. Basically use new Slicer 2.6.0 beta3.
Google github prusaslicer 2.6 and you should find a zipped download. Save to a suitable folder and unzip. It doesnt install like a usual app. Just runs.
However, take care to NOT say yes if it asks to import configuration of existing slicer. Choose a fresh install. MK4 will be available in the config wizard now.
I actually made that mistake and had to uninstall everything and try again from fresh start. Still it asked to import existing config. Just say NO!
Well, while using the 2.6 beta is an option, I can see the Mk4 in my install of 2.5.2. I would export my config profile from 2.5.2, and do a clean re-install to see if the MK4 shows up. Then reload my saved profiles.
Just go to Configuration > Check for Configuration Updates. That should do the trick.
It wasn't in the configuration wizard. Had to close the app and reopen. Then it identified there was a configuration update.
