MK4 Profile not in PrusaSlicer 2.5.2
[Gelöst] MK4 Profile not in PrusaSlicer 2.5.2
mpilchfamily@msn.com
(@mpilchfamilymsn-com)
Just received my pair of MK4s today and installed PrusaSlicer 2.5.2. When i go into the Configuration Wizard i don't see the MK4 as an option. Where do i go to get the latest MK4 profile for PrusaSlicer?
Veröffentlicht : 02/06/2023 12:38 am
WillBehave
(@willbehave)
Mitglied
RE: MK4 Profile not in PrusaSlicer 2.5.2
Hi.  I had same problem.  Prusa support helped me track down solution.  Basically use new Slicer 2.6.0 beta3.
Google github prusaslicer 2.6 and you should find a zipped download.  Save to a suitable folder and unzip.  It doesnt install like a usual app.  Just runs.
However, take care to NOT say yes if it asks to import configuration of existing slicer.  Choose a fresh install.  MK4 will be available in the config wizard now.
I actually made that mistake and had to uninstall everything and try again from fresh start.  Still it asked to import existing config.  Just say NO!
Veröffentlicht : 02/06/2023 9:05 am
Well, while using the 2.6 beta is an option, I can see the Mk4 in my install of 2.5.2. I would export my config profile from 2.5.2, and do a clean re-install to see if the MK4 shows up. Then reload my saved profiles.
Veröffentlicht : 02/06/2023 10:52 am
Walter Layher
(@walter-layher)
Just go to Configuration > Check for Configuration Updates. That should do the trick.
Veröffentlicht : 02/06/2023 11:13 am
It wasn't in the configuration wizard. Had to close the app and reopen. Then it identified there was a configuration update.
Veröffentlicht : 02/06/2023 11:27 am
