macOS PrusaSlicer 2.4.0+arm64 generates import error on STL file exported from Inventor 2022
DominikHoffmann
(@dominikhoffmann)
PrusaSlicer import error on macOS
What am I doing wrong? This is my STL file.
Opublikowany : 25/02/2022 4:13 pm
RE: macOS PrusaSlicer 2.4.0+arm64 generates import error on STL file exported from Inventor 2022
You file slices ok on 2.4 Linux  Intel CPU...
BUT it also fails to load on the Raspberry Pi build, also arm64.  You are doing nothing wrong.
Send a bug report: quote this confirmation if you want to add urgency.  Prusa will need the offending file and possibly the source file.
BTW: the design would be simpler to print without the riser feet at the screw mountpoints.
Opublikowany : 25/02/2022 7:25 pm
DominikHoffmann
(@dominikhoffmann)
Posted by: @diem
You’ve got a good point. My colleague sliced it for me on his PC, and the part is now printing with support material underneath. For next time I will use washers instead of those feet.
Opublikowany : 25/02/2022 7:30 pm
DominikHoffmann
(@dominikhoffmann)
Posted by: @diem
Filed it here:
https://github.com/prusa3d/PrusaSlicer/issues/7987
Opublikowany : 25/02/2022 8:26 pm
Excellent.
Opublikowany : 26/02/2022 1:25 am
