Color Change With Sequential Printing
Ortheis
(@ortheis)
Hey everyone,
I run a 3D print service/3D modeling company and use little keychain swatches to show off my colors. I would like to print them using the 'Sequential Printing" option in PrusaSlicer but it says I can not do a color change when using said feature. I also use Mini+ printers so MMU is out of the picture.
Does anyone by chance know if there is a work around or why this is the case? Any help is greatly appreciated!
Running PrusaSlicer 2.5.0
Best Answer by Crab:
I think that has been an issue for a while.. IT is in GitHub as a feature request.. just hasn't been implemented. There are work arounds.. and I can't remember what they are.. but you can insert gcode after a sequential model is done..
 .. just looked it up..
under PRINTER SETTINGS > CUSTOM GCODE there is a "BETWEEN OBJECTS GCODE box where you can add custom gcode..
In this box add:   M600 (if that is the code for filament change.. not sure it is I haven'ty looked it up)
You can just use for that one print or save as new printer for when you want to do it again.
Napsal : 18/03/2023 9:10 pm
Crab
 Crab
(@crab)
RE: Color Change With Sequential Printing
Napsal : 19/03/2023 11:49 pm
1 lidem se líbí
nurp
 nurp
(@nurp)
I wonder if the UI changed because I don't see that setting. There is Print Settings->Output Options->G-Code substitutions or Post processing scripts.
Edit: Found it by searching it. Was under Printers
This post was modified před 2 months by nurp
Napsal : 18/04/2026 7:57 am
1 lidem se líbí
