unable to resolve underextrusion
jbpr
 jbpr
(@jbpr)
Membre
Dear Core One community
sorry for the long post, but it has become a rather long story so far...
I have a very strange issue with my Core One + that I have bought as an assembly kit. At first I tried to resolve the issue by searching through the forum posts and other online resources, but could not find any solution. I have then contacted Prusa chat support (multiple times) and spent quite some hours with them analysing the issue.
As a last resort they are now suggesting that I send the assembled printer back to them for further checking. However, I would really like to see, if one of you has come across a similar issue or has any suggestion that was not yet covered by Prusa’s support team.
What is going on is the following:
I have assembled the printer beginning of December last year. Assembly worked fine, all self-tests passed on first startup and printing worked out perfectly. I only printed PLA so far, most of it being Buddy 3D PLA but also some other brands like eSun or extrudr - but for the most part Buddy 3D.
Now, beginning of February this year (about 8days of total printing time according to stats), more or less two months into printing results without any complaints, the Core One started to underextrude. And so far there was no way to resolve the issue.
  • The first suggestion by Prusa support was that the thermistors might read a wrong value. Even after the multimeter resistance values read all in the proper range, we agreed to change the hotend thermistor. That change did not bring any result.
  • In the second session, Prusa support suggested it might be a clogged nozzle. Cold pulls, however, were apparently looking as they should and also did not show any signs of “old”, stuck filament. Changing the nozzle also did not resolve the issue.
  • In the meantime I have bought a filament dryer and dried the PLA filament, which was until then only stored in the plastic bags with some drying bags inside. The underextrusion issue did occur on already opened filament, dried filament, newly opened filament.
  • I have also found that playing around with the idler lever tension screws somehow reduces clicking sound a little bit - but the overall issue with clicking and underextrusion still persists. And to notice any effect I have to open the screws far over what was described in the assembly manual.
  • In the meantime I had also disassmbled the complete gear box, reassembled it and ran a gearbox alignment - which showed no issues.
  • The next Prusa support session suggested that it might be worth trying to exchange the extruder motor. Which was done. Since the extruder motor shipped with the hotend heater as well, I replaced that as well. I.e. the hotend only had the aluminium block that was not changed.
  • The motor also did not bring any result to my problem.
  • Next support session suggested to exchange the loveboard. Again said and done. Unfortunately no solution.
  • The next time I contacted Prusa support they suggested to exchange the complete hotend as one part. Did that and was able to print one 1×2 gridfinity bin without any issue. However, the second print again failed with underextrusion. With the new hotend, support also shipped a roll of PETG to make sure it is not a filament related issue. However, also with PETG the issue persists.
General: The issue appears when feeding filament through PTFE tube and when feeding directly to the extruder. Pushing filament through the extruder when doing a cold pull works fine.
Currently when I send the gridfinity bin 2×3 to the printer, it starts out looking fine, but after about 4 layers, it startes to underextrude again. No print finishes anymore.
I am waiting now for Prusa support to ship a box big and stable enough to ship back the assembled printer. Maybe someone has clue on what else to check before I ship the printer back...
Publié : 15/03/2026 11:45 am
jbpr
 jbpr
(@jbpr)
Membre
RE: unable to resolve underextrusion
I was too slow editing the last post...here are two pictures of what it looks like at the moment. It starts out with layers that are fine and then gets quite bad...
Publié : 15/03/2026 11:54 am
Conrad
(@conrad-2)
IMO, the Nextruder shouldn't be clicking at all. Divide and conquer! Either the Nextruder can't pull the filament for some downstream reason, or there's something wrong with it. I can't imagine it's a problem with PLA, but just to be sure, pull the Teflon tube out of the Nextruder and try to pull filament through it from that end. It should be easy. I mention this only because I found some soft filaments can easily be pushed from the spool end but are impossible to pull from the head end. If you can pull easily, then the problem is (most likely) something to do with the Nextruder assembly. Make sure the bearings in the arm (no doubt it has a name!) turn freely and smoothly. The ends of the tension screws should be flush with the end of the threaded hole. Double check how far the nozzle extends from the block. You've already checked and changed most of this, so I'm hoping you'll find some problem that binds up the filament on its way to the Nextruder.
Publié : 15/03/2026 5:58 pm
1 personnes ont aimé
jbpr
 jbpr
(@jbpr)
Membre
Thanks for your response. What do you mean by the bearings in the arm that should turn freely and smoothly? The cable and ptfe tube are only fixed to a very small arm which is moving freely.
I have removed the tube from the extruder. Pushing filament through it from the nextruder side does not feel any different than what it does from the regular side. I ran another test with feeding the filament directly into the extruder. I have also made sure the idler screws are level with the part.
The printing got a little better. However, only when more or less constantly making sure the filament is not going into the nextruder in a sharp corner and keeping the top lid open of course. As you can see in the picture the closer to the top (the bin is sideways) the more missing lines. But also at the very bottom you can see missing lines.
Publié : 15/03/2026 7:35 pm
This looks like a partial clog due to heat creep. PLA can get soft in the heat break tube which creates a temporary plug that blocks flow. Pressure builds up and pushes the plug through which then builds up again and re-blocks. This is what causes the gaps.
Check the chamber temp, make sure it stays below 35°. Open the door if necessary. Also try decreasing the nozzle temperature by 5-10°
Is this a gridfinity box? One trick is print two side by side which forces a travel move between each layer. Part of the problem is that heat from the part itself could be softening the filament in the heatbreak tube.
This is precisely why I don't print with PLA anymore. I would use PETG or PCTG here instead.
Ce message a été modifié il y a 8 hours 3 fois par hyiger
Publié : 16/03/2026 1:29 am
Forgot to emphasize in my previous post: decrease nozzle temp 5° and open the door.
Publié : 16/03/2026 1:49 am
Conrad
(@conrad-2)
If you feed the filament directly, that should eliminate downstream problems with the tube and such. Just for clarity, I meant pull the filament from the Nextruder end because that's what the Nextruder has to do. Pushing and pulling can be very different in terms of friction and binding. If it's not mechanical, I think @hyiger might be on the right track. PLA should be the easiest thing in the world to print- until it isn't. Has your printer environment changed since it was working well? Change of seasons, heat on or off, air conditioning. I keep temperature and humidity monitors logging data continually.
Publié : 16/03/2026 3:46 am
jbpr
 jbpr
(@jbpr)
Membre
Thank you folks, for your feedback. Very much appreciated.
In fact, during my troubleshooting efforts I have read about heat creep but did not really follow up on it.
My environment is, from what I would say stable. The printer is situated in a heated room and environment temp should not have changed much over time. Also, all the prints so far, which were as mentioned only PLA, were printed with the door closed and the top vent automatically opened by the printer. In addition to that it did not make any difference in those two months whether I opened the window in the room to get fresh air in or let it stay closed. It also did not matter whether I started prints on a cold printer or printed a whole day through. All outcome was perfect.
But to be honest, I haven't paid much attention to the chamber temperature. However, would that not be regulated by the chamber fans? They are set to auto mode.
Regarding the suggestion to use PETG instead: This is what Prusa support wanted me to test as well, why they shipped a roll PETG prusament. The results with a gridfinity bin sliced with the default Slicer settings for Prusament turned to bad in the first couple of layers. See the image below....
--> I will certainly give the print another try with the door opened and let you know how it goes.
PS IMO having to open the door while printing would not really make sense to me. Why would I buy a printer with an enclosure, if I have to keep it open manually? Why would the printer have a door sensor that stops the print when opening the door by default?
Publié : 16/03/2026 5:30 am
