Core One skipping steps/Layer shift
Página 1 / 2
Enrique Specht
(@enrique-specht)
Miembro
Hey guy's,
we recently got the core one for our workplace. Since then I frequently have trouble with severe layer shifting. I have tweaked my profiles a but only basic settings like infill pattern, support material etc. The speeds and acceleration are based on the 0.2 speed profile in prusa slicer. I turned off ramping z lift but that didn't fix it. I checked the belt tention but nothing unordinary. The layer shift seems to happen after about 10 to 15 mm and not always in the same direction.
Any help is greatly appreciated,
thanks in advance!
Respondido : 14/04/2025 10:30 pm
andhson
(@andhson)
RE: Core One skipping steps/Layer shift
mine did this as well early on like my second print, in my case one belt was looser at 75hz. I tuned belts and found that the reason they were uneven was likely that they squared the x-y axis this way, with tuned belts I had a tiny gap on the left side. I went through the procedure to square the x-y axis, I used printed shims of ASA, after quite a bit of trial and error I got it square and retuned belts. Since then my layer shifts are gone, also it is homing consistently without headbanging.
/Anders
Respondido : 15/04/2025 9:16 am
Boris
(@boris-3)
Did you use completly stock settings?
There is a current bug in the software that creates a layer shift at fast print speeds with arc fitting turned off or avoid crossing perimeters on, mostly on round objects. https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/4573
Respondido : 16/04/2025 6:29 am
1 les gusta
Enrique Specht
(@enrique-specht)
Miembro
Interesting, I never heard of this setting before.
My settings are not 100% stock. I changed stuff like number of perimeters, infill pattern and density, generate support material etc. All of these are what I would consider basic settings which are likely to be tweeked at some point anyway.
I searched for arc fitting and avoid crossing perimeters which are set to enabled: G2/3 IJ and the other is disabled. Although this constalation should not cause this bug, I found out that this problem somehow is caused by high speeds, I'm suspecting bad stepper drivers or something. Since my original post I contacted prusa. It's likely I'll be sending the printer in for a check and repair.
Respondido : 16/04/2025 7:25 am
1 les gusta
Laurenz
(@laurenz)
Try to print the same item with original settings. - If it works, it is your changes, if it also does not work, it might be hardware or this slicer bug.
I also had big troubles with my ecoPLA (from 3DJake). I used a profile for this filament that worked well on my Ender, but it completely fails the first layer on CoreOne.
so, just switched to GenericPLA and all was fine (and much more faster).
Respondido : 16/04/2025 9:28 am
altaic
(@altaic)
Posted by: @enrique-specht
[…] I found out that this problem somehow is caused by high speeds, I'm suspecting bad stepper drivers or something.
That sounds like what I’ve been experiencing. I filed a bug report at the firmware repo here.
Please have a look, and if you think it’s the same and can post your gcode file there, that would be really helpful. Might even get it fixed faster 🙂
Respondido : 18/04/2025 3:11 am
andhson
(@andhson)
Posted by: @boris-3
I must admit that it is likely that I used the don’t cross perimeters on a model with round cutouts when layer shifts happened, so in my case it may have been caused by this bug, not belt tuning.
/Anders
Respondido : 18/04/2025 7:57 am
1 les gusta
James He
(@james-he)
I turned on the avoid crossing perimeters from day one.
and cause all kind of trouble.
after I turn this option off, everything works now.
Many thanks, James
Respondido : 28/04/2025 4:52 pm
2 les gusta
RFT2112
(@rft2112)
Had this happen with my latest print.  Using .15mm speed setting.  Happened about 2mm in Z height.  Heard a slight slap of the extruder head bang on something in the X or Y axis. Next layers were offset in the X and Y.
Esta publicación ha sido modificada el hace 11 months por RFT2112
Respondido : 19/05/2025 5:11 pm
Raaz
 Raaz
(@raaz-2)
Please Upload the Prusa Slicer project, so we can check the speeds and movements, when it happened.
For me, it was the "avoid crossing perimeters" settings, that made my printhead try to change direction without slowing down at 350 mm/s travel speed.
You can still use that settings for less stringing etc., but the travel speeds need to be slowed down a lot, like 50 mm/s.
Respondido : 20/05/2025 4:05 pm
1 les gusta
RFT2112
(@rft2112)
Not having great success at uploading file.  Hopefully this works.  I had to compress the file so I've also attached a zip file
15mmspeed.obj
Respondido : 20/05/2025 5:25 pm
RFT2112
(@rft2112)
I will look into those settings,
Thank you
Respondido : 20/05/2025 5:27 pm
Joe
 Joe
(@joe-14)
Miembro
Thanks for your comment, it save me today (12 Aug 25)
I tried using Avoid crossing perimeter for the first time to avoid some stringing on a TPU print top surface. I had printed this model before 20 times and once I changed this setting, layer shifts every time...
Seems like it has not been addressed in the firmware all these months later. My slicer and printer firmware are all up to date.
Core One Printer / TPU Print
Respondido : 12/08/2025 12:45 pm
1 les gusta
Greg's Maker Corner
(@gregs-maker-corner)
I have been trying to print a part (also a part I sell) and am running into the same issue with layer shifting. I have re-tensioned belts and still get consistent layer shifting, though it's not always in the same spot. Due to the nature of the part, I have to use the "Avoid crossing perimeters" feature in the slicer. Based on this bug I believe that is the root cause of my issues. I haven't had any layer shifting on other prints on this printer.
I noticed that the printer makes violent travel moves before the layer shift occurs. It appears that the printer is also ignoring any settings in my attempt to override the very rapid travel. I am printing in "normal" mode, not stealth mode.
I am on 6.3.4+10511 of the firmware.
Respondido : 13/09/2025 11:48 pm
Greg's Maker Corner
Greg's Maker Corner
Here is another image where the layer shift was about half way through the print.
Respondido : 13/09/2025 11:49 pm
wdvc
 wdvc
(@wdvc)
I am experiencing the same issue, with a printables model for a 10" rack. after the 2nd layer is finished it skips. I have tried this print twice, and before spending more time on it searched and found this topic.
double-5u_0.4n_0.2mm_PETG_COREONE_14h16m
Respondido : 23/09/2025 8:05 am
Martin
(@martin-38)
Miembro
I seem to have the same, or at least similar problem. I experience a massive x/y shift at about layer 200 (not consistent though, PETG, 0.2mm balanced, also PLA 0.2 fast settings).. I recalibrated.. re-tensioned belts. I always have "avoid crossing perimeters" turned off.. Test prints turn out fine. I think everythings in order and I start a bigger project and it occurs again. Any help?
Respondido : 23/09/2025 6:54 pm
Jane Davis
(@jane-davis)
Miembro
I am having the exact same problem. The location of the shifts (often many occur in one print) is random and not repeated on the same layers. I have the high pitched whine (scream) as it loses its way as well. The shifts are 100's of mm in both axes. As someone who has written precision multi-axis CNC routing code for commercial machines - Prusa has a very serious problem with this. I would suspect stack overflow or integer overflow somewhere that taints the stepper control timing. It can also happen if computations or assignments which have to be atomic are not. The code authors need to step up.
Respondido : 29/09/2025 7:56 pm
1 les gusta
Jeeves
(@jeeves)
Miembro
I stumbled upon this thread after I'm having the same issue... but mine is at exact same height.
I did belt tuning, in-fact.. more than 5 time in last 4 weeks to reduce VFA, also calibrated IP and phase step.. Between the first and second, I have tuned belt and between the 3d (you will see a video) I loosen belt and tuned again with prusa's built in manual belt tuning.
  • I sliced using Orca slicer
  • Did turn on the Avoid wall crossing
  • PLA 0.2mm FAST profile
  • NOT IN VASE mode, I wanted to print with small infill..
First 2 that failed From the video,, I stopped after recording video
Download the PLA > VasePlaneV5_0.4n_0.25mm_PLA_Prusa CORE One HF_1h26m
(Uploaded a video, hope it shows up! otherwise, I will upload elsewhere)
Esta publicación ha sido modificada el hace 7 months por Jeeves
Respondido : 06/10/2025 2:02 pm
Página 1 / 2
