Pressure advance code not working
MK Ultra
(@mk-ultra)
I recently started using the input shaper settings for prusa XL, in the speed setting, i realized that my model, especially at the edges has this "scarring" around tight corners. I realized this is because the PA is not set properly i assume. I created a PA calibration from garethky.github.io/PrusaSlicerPressureAdvanceCalibration/ . after adding this function into the custom G-code part of the filament settings in prusa slicer
{if nozzle_diameter[filament_extruder_id]==0.4} M572 S0.02 ; Set Pressure Advance to 0.02{endif}
I experienced no difference. Where do i go to properly input the PA number for the prusa XL?
Veröffentlicht : 23/06/2024 3:17 pm
BaconFase
(@baconfase)
RE: Pressure advance code not working
Just have to change the single number here:
Veröffentlicht : 24/06/2024 3:54 am
