Mesh Bed Leveling Tuning
Bigdogbro1
(@bigdogbro1)
Is there a way to tune the mesh bed leveling map on the MK3? A method to adjust the corners and center to better correct the mesh information.
I have about 5/1000 or .005 (my guess) of an inch too high in the front right corner. I can see it when I do a 1st layer. Would be nice to have an easy method to correct this.
MK3 Kit, Designed, built 4x4 CNC Plasma Cutting Table, Motorcycles Bigdogbro's Adventures
http://www.youtube.com/channel/UC5djrxBeeOKB9_6rHnn6G8A
Napsal : 04/03/2018 1:13 am
imod.systems
(@imod-systems)
Re: Mesh Bed Leveling Tuning
I noticed a similar issue with mine and support sent me this: https://help.prusa3d.com/l/en/article/TPGip0OmaP-bed-level-correction-kit-only
Napsal : 04/03/2018 2:51 am
themzlab
(@themzlab)
I tuned with a different method but at the moment I have not been able to find the instructions. If you can find them - it is fairly easy.
First, run a mesh bed level with G-code command, second run another gcode that will cause the results to be printed. They are printed in a sensible order in a 3x3 grid and it is pretty straightforward to see if you have one low or high corner. I pasted the values into EXCEL and did a conditional formatting with color to visualize it. I tested this by putting a tiny piece of paper under one corner of the magnetic bed and re-running the procedure to prove that I had the orientation correct.
I shimmed the rear-right mount point of the Y-axis shaft to raise that corner. The end result is a level but but it is a tiny bit high in the middle. If I cared to, I could remove the spacer in the middle and replace it with a shorter one or grind of a tiny bit of height to lower the middle. I've never really had a problem with bed level; I did this tweak just because it could be done : )
Napsal : 04/03/2018 2:59 am
Kyle
 Kyle
(@kyle-3)
I have the same issue on the front right corner.
Napsal : 04/03/2018 4:10 am
thrawn86
(@thrawn86)
https://help.prusa3d.com/l/en/article/3tSXh6nWJd-pinda-probe-testing
this is pretty enlightening too, along with the explanation of those values here https://shop.prusa3d.com/forum/original-prusa-i3-mk2-f23/finding-the-perfect-live-adjust-z-offset-proposed--t2499.html
Mine is kinda shit:
Napsal : 04/03/2018 6:57 am
Bigdogbro1
(@bigdogbro1)
Thanks!
I will give those methods a try. First I want to actually check the mechanical level surface with a dial indicator so I know what I am starting with. If the PINDA probe thermistor is not accurately compensating then I need to find that out. I realized the thickness variation of the two wall skirt on prints done later in the day so something mechanically has slightly moved or it is a variation of PINDA accuracy and control.
UPDATE:
I did have a tiny spec of squished plastic under the front right corner about 3"x3" from center where my squish is but it didn't help much when removed.
Well I set the mesh bed fine tune settings, left side to -48, right side to 48, front to 10 and rear to -10.
I still get a bit of more squish on the right side and RH front corner of the two wall skirt runs but it has improved. I am assuming that the skirt follows the mesh map as well. I will need to mechanically check the bed tram when I get the appropriate indicator.
Prusa needs to think about adding more the +-50um for mesh adjustment or get better PINDA created mess accuracy I feel.
Napsal : 04/03/2018 3:22 pm
martin.m25
(@martin-m25)
You might want to print a Z test pattern and measure the thickness using calipers (or an outside micrometer). I made my own test pattern (size optimized to calipers - not perfect yet), but you'll find others on Thingiverse. Just printed it and measured:
0.2 0.2 0.2
0.21 0.2 0.24
0.22 0.19 0.29
So front right is too thick, needs some adjustment. Unfortunately the bed level tuning doesn't allow the tuning of a certain corner, you'll have to puzzle this together using front, right... controls.
- Martin
- Martin
Napsal : 04/03/2018 5:23 pm
Brigandier
(@brigandier)
https://github.com/prusa3d/Prusa-Firmware/pull/514 relevant.
My MK3 Parts: [Bowden] [New Shoes] [TPU Micro Springs]
Napsal : 04/03/2018 6:11 pm
Bigdogbro1
(@bigdogbro1)
Thanks for the link Brig.
That GitHub post is interesting and would like to know if Prusa can confirm.
After doing multiple iterations of the mesh tune I would assume the PINDA has been exposed to the bed heat enough to have the temp compensation kick in.
Thanks for the test pattern, Martin.
The mechanical check will confirm.
I ordered this small .0001" resolution test meter. http://www.shars.com/products/measuring/dial-test-indicators/008-dial-test-indicator-0001
Cheers
Napsal : 04/03/2018 6:56 pm
martin.m25
(@martin-m25)
How do you intend to mount the meter? I just printed the test pattern and measured it using calipers.
- Martin
- Martin
Napsal : 05/03/2018 9:33 pm
Bigdogbro1
(@bigdogbro1)
I will clamp to the extruder stepper motor with a measurement indicator jointed holding arm and mount the indicator on the end. I will post a picture when I get the indicator.
Napsal : 06/03/2018 3:22 am
martin.m25
(@martin-m25)
Good idea, magnetic holder on the motor. A pity that front and back parts are proably aluminium. BTW I remember having to pay Fr. 600 for a 1 um gauge, these things got much cheaper it seems.
I just measured the effect of the bed level correct function, Z test pattern thickness from back to front:
Corrections all 0:
0.25 (0.27) 0.25
0.2 0.19 0.2
0.2 0.21 0.26
Correction right -50 um:
0.24 0.21 0.27
0.22 0.22 0.23
0.23 0.25 0.25
I'd say the correction does not work.
- Martin
- Martin
Napsal : 06/03/2018 7:34 pm
Bigdogbro1
(@bigdogbro1)
The indicator holder has a screw clamp on it which I hope will grab onto the front of the motor good enough.
The equipment comes in Thursday.
http://www.shars.com/indicator-holder-clamp-mount
Napsal : 06/03/2018 8:13 pm
