[Closed] Meanwell LRS-350-24 PSU fan control
Super Slim
(@super-slim)
Would it be safe to replace the 12V on/off  60mm fan  (17cfm), with a 92mm pwm fan(46cfm), and run the fan at a low PWM, so it is always running, and have the Meanwell temperature controlled on/off 12V fan power also connected to the fan (via a diode!), in case the PWM % power is set too low?
Napsal : 15/12/2019 8:24 pm
Patrick McNamara
(@patrick-mcnamara)
RE: Meanwell LRS-350-24 PSU fan control
Posted by: @dsowden
Just use something like:  https://www.thingiverse.com/thing:3197058 (92mm) or https://www.thingiverse.com/thing:3406054 (80mm) with a "silent" fan and let the Meanwell drive it directly.  You won't be able to hear it.  I use the latter with an Arctic F8 Silent (15.1CFM) and it is silent sitting on my desk, two feet away.  Keep the power supply plenty cool.
Napsal : 15/12/2019 9:32 pm
Patrick McNamara
(@patrick-mcnamara)
Posted by: @dsowden
No need for the complexity.  An 80mm, 15.1CFM fan keeps the supply plenty cool.
I use the 80mm plate with an Arctic F8 silent and let the power supply drive it.  It's effectively silent sitting on my desk, two feet away.
Napsal : 15/12/2019 9:35 pm
Super Slim
(@super-slim)
@william-m51
Thanks, I will try it with ther standard wiring!
Napsal : 16/12/2019 11:53 pm
Super Slim
(@super-slim)
@william-m51
Thanks, I will try it with the standard wiring!
Patrick McNamara
(@patrick-mcnamara)
@dsowden
Unless you want to figure out what the Meanwell fan connector is and order one, you will have to splice the Meanwell connector onto your new fan.
Napsal : 17/12/2019 2:30 am
Super Slim
(@super-slim)
@william-m51
I have not received my LRS-350-24 PSU yet, so is there  two pins on the PSU motherboard for the 12V fan?
Napsal : 17/12/2019 9:18 pm
