Vase mode slicing gaps
Kaemer1645
(@kaemer1645)
Hi everyone,
I'm using 0.6 nozzle to print the vase on a vase mode o.3mm layer height. The main problem is that I have got small gaps on a printed model. I was trying to solve it using "Slice gap closing radius" in different values from the range 0.1 to 0.0005 but nothing helped. Also, I'm trying different layer heights. Can anything be done about it or whether it is a specificity of printing like seam?
All the parameters are in 3mf.
I will be very grateful if someone explains what is going on.
I attached some photos, stl and 3mf file in zip.
Slicer: PrusaSlicer 2.5.0
vase_mode_gaps
Opublikowany : 11/09/2022 9:17 am
Ringarn67
(@ringarn67)
RE: Vase mode slicing gaps
@kaemer1645
That part is not designed for vase mode!
Vase mode is possible when parts are completely solid, with no inside.
Your part has a hole through it.
Prusa i3 MK3S+ FW 3.11.0 (kit dec -20), PrusaSlicer 2.6.1+win64, Fusion 360, Windows 10
Opublikowany : 11/09/2022 9:56 am
Kaemer1645
(@kaemer1645)
But when I insert solid, the same is happening.
Opublikowany : 11/09/2022 9:59 am
Ringarn67
(@ringarn67)
It is the big hole in middle that is the problem.
For vase mode part should be without hole...
A solid cylinder is ok, a pipe is not ok.
There is no stl file in your upload...
Opublikowany : 11/09/2022 11:00 am
Kaemer1645
(@kaemer1645)
I added stl, 3mf and new photos of printed vase.
vase_mode_gaps2
Opublikowany : 11/09/2022 11:14 am
Per https://help.prusa3d.com/article/layers-and-perimeters_1748#spiral-vase :
The model should be defined as a solid. Otherwise, PrusaSlicer will try (and fail) to create both inside and outside surfaces, so model the outside dimensions only.
Opublikowany : 11/09/2022 12:01 pm
Ringarn67
(@ringarn67)
@kaemer1645
Added two cylinders to clarify what i mean.
It would be much better to adjust it in cad-program
edit: File was to big, had to simplify model
Opublikowany : 11/09/2022 12:06 pm
Kaemer1645
(@kaemer1645)
Sorry for your time, but I added STL at 11/09/2022 11:14 am but it still waiting for approval by a moderator.
Opublikowany : 11/09/2022 12:31 pm
Kaemer1645
(@kaemer1645)
Maybe someone have got some other advice how to solve this holes, because I still don't know how to solve it.
Opublikowany : 12/09/2022 9:02 am
Ringarn67
(@ringarn67)
@kaemer1645
This is what came out of my 0,4 nozzle printer 0,3 DRAFT, all standard settings except Vase mode ON, ZERO Bottom layers and CLASSIC Perimeter Generator
I noticed you have made a lot of changes in your profile(s).
When I run into problem I go to standard settings and "start all over", for me that works most of the time.
This is a rather small model so your 1,2 perimeter width may cause trouble...
Opublikowany : 13/09/2022 10:47 am
1 ludzie polubili
Kaemer1645
(@kaemer1645)
The main rule is that i would like to print it in vase mode. I need to use 0.6 nozzle with 1.2 width to get appropriate strength. For now i changed the model, I densified the vertical pipes around the main shape in order to remove this gaps. I haven't got any idea how to solve it. In vase mode at the joins model shifted layer inside. I don't know why because while I'm printing without vase mode but using 1 layer perimeter it didn't happen. Of course in that case I got seam. For now just model will be a little different. But I really appriciate for your help. Mayby in future when i got more experience i find solution.
Opublikowany : 13/09/2022 11:09 am
Kaemer1645
(@kaemer1645)
And I think, you have got this gaps here. But you used smaller nozzle and silk filament.
Opublikowany : 13/09/2022 11:13 am
Ringarn67
(@ringarn67)
@kaemer1645
The gaps come from model, below  5,05 mm there is a straight edge between pipes, and over 5,1 there is a sharp corner.
In vase mode there will be gaps.
Not silk, Prusament PLA. (old and probably wet 😀 )
Glad you could make it work 👍
Opublikowany : 13/09/2022 9:10 pm
1 ludzie polubili
