[Resuelto] TROUBLE WITH TAULMAN ALLOY 910
Enrique
(@enrique)
Hi everybody. I have a MK3S+, and I bought a spool of Taulman 910. The printer doesn´t have any set for hot end temp and bed. So, on the Prusa Slicer, manually, I set hot end to 270°C and bed to 65°C, all the speed set to 30 mm/s, but when it starts to print, the printer makes the purge brim, and instantly stops, asking for filament change. So I push the button, it pulls out the filament, I insert it again, so the printer resumes the printing but stops again asking for filament change and it keeps going with the same problem.
Best Answer by Diem:
That might be a problem with your filament sensor.
As a check, turn off the sensor (LED Menu) temporarily.  If the printer behaves reinstate the sensor then check the sensor is clean and clear of stringing/debris, check connections, and test whether manually inserting and removing filament triggers the sensor...
Respondido : 04/02/2022 4:52 pm
Respondido : 04/02/2022 5:59 pm
Enrique
(@enrique)
RE: TROUBLE WITH TAULMAN ALLOY 910
Hi there Diem. Thanks 4 the tip. Right now I have turned off the filament sensor and it worked. I´m printing a medium sized piece and its doing it well.
Just having this problem with Taulman. Other filaments, even PC, work fine using the filament sensor On.
Respondido : 10/02/2022 7:51 pm
Enrique
(@enrique)
Also I want to recall that the printer doesn´t have any temp. set for Taulman, so I use the temp preset for Flex to insert the filament, and in Slicer, I use the preset of Taulman Bridge.
Posted by: @enrique
Respondido : 10/02/2022 7:54 pm
