Stringing on bridging
I am having the following problem with stringing on the underside of a bridged piece at 90 degrees. I used to not have this problem and it prints fine on my mini. I recently rebuilt my nozzle which is the major change. The area in the middle should be flat. I’ve got my extrusion working perfectly (tell it to print 100mm of filament and it does). My cooling fan is set to 100% and I’ve even tried under extruding. The v shape area on the right is where I removed the prusaslicer generated supports. Any suggestions would be greatly appreciated. Thanks.
Publié : 12/12/2021 12:17 am
