Prusament ASA solid top layers deform part?
bnx
 bnx
(@bnx)
I'm a huge fan of the signal white thus want to print the Prusa parts using ASA Signal white. I know that ASA is prone to warp and not simple to print.
I'm using the default Prusa Slicer ASA profile without a housing.
I've noticed that solid top layers shine through the whole part and deforms them (see the overhang in picture 1). I assume thats caused by the huge heat difference.
I also see that the layers seem to be rough. (see picture 3)
How can I improve the layer print quality and prevent the solid layer shining through?
Anything else which seems to be wrong on the pictures I can improve?
Here are a couple of pictures of my last try (also without a high skirt here and it warped a bit caused of that - next try I'll print a high skirt with it 🙄 ):
Posted : 09/03/2022 7:45 am
towlerg
(@towlerg)
RE: Prusament ASA solid top layers deform part?
When you say "high skirt" do you mean draft shield? because if you don't you should try a draft shield.
Posted : 09/03/2022 12:34 pm
bnx
 bnx
(@bnx)
Thank you for your reply. What I mean is adding an „oval skirt“ as described in the prusa blog post for printing ASA
https://blog.prusaprinters.org/asa-prusament-is-here-learn-everything-about-the-successor-to-abs_30636/
Posted : 09/03/2022 1:02 pm
Search for 'buldge' on the forum.  Common issue with PS and no one way to stop it.  Some materials show it more than others too.
Posted : 09/03/2022 1:03 pm
bnx liked
towlerg
(@towlerg)
This article is a little old, the oval skirt is now generated automatically by Prusaslicer and is selected in Print settings/Brim and Skirt. It's been in Prusaslicer for the last couple of releases.
This post was modified 2 years ago by towlerg
Posted : 12/03/2022 12:32 pm
