Prusa Slicer disappearing part
Philipp H.
(@philipp-h)
Dear Experts,
I make all my cutters with a 4mm deep and 0.5mm thick cutting edge. Here i have a set that uses the cloud shape in the prusaslicer to take away the cutting edge before slicing. What could be the reason for this?
See attachment please.
Thank you in advance
Philipp
Respondido : 15/05/2022 1:50 pm
Robin
(@robin)
RE: Prusa Slicer disappearing part
You might get better advice when posting your zipped project file from Slicer but I'd start with "detect thin walls". https://help.prusa3d.com/article/layers-and-perimeters_1748#detect-thin-walls
Respondido : 15/05/2022 1:57 pm
Philipp H.
(@philipp-h)
Thank you for your reply. "Detect Thin walls" are always on.
The Project file is as wetransfer link:
https://we.tl/t-dq1tZkhYQX
Don't know how to upload an project file.
Respondido : 15/05/2022 2:01 pm
Robin
(@robin)
You need to zip it.
Respondido : 15/05/2022 2:05 pm
Philipp H.
(@philipp-h)
Ok, next try 🙂
Respondido : 15/05/2022 2:19 pm
Robin
(@robin)
That's not PrusaSlicer cutting the edge. Your file does not contain the edge, probably something went wrong exporting the mesh from wherever you designed that.
This is how your file looks after importing it in Fusion360:
Respondido : 15/05/2022 2:20 pm
Philipp H.
(@philipp-h)
Capriciousness of freecad. You do the same thing 3 times and the third time it suddenly doesn't work. Now the exact same process has brought the desired result. Thank you for your time and please excuse the waste of it.
Respondido : 15/05/2022 2:51 pm
