Print speed numbers differing
Hi all,
Just got back into printing again recently and I have noticed my print speed legend is showing a total time of over 5 hrs when the totals do not add up to such. I understand that this is likely something simple hidden from the legend, such as travel times but would be grateful if someone could maybe shine some light on this for me. I have attached a link to the file in question (I hope), you may also see within the settings things like high retraction and wipe which are remnants of me trying to fix a stringing issue that has not yet been completely fixed (I have been using a stringing test model for that and not the model within the current scene) but has been almost eliminated within these settings.
Not looking for any help with the stringing issue in this post, but I will take any tips you have, just thought id mention why the settings may look strange.
RE: Print speed numbers differing
Have you repaired the errors in the STL?
Joan
sorry it was not. Should find a repaired model within this file
