PLA Globbing and Burning
I've been messing around with this for a couple of weeks. Before I started tweaking settings, I would get tons of these burned gobs through out a print.
I thought that the nozzle was correctly adjusted but I'm starting to Now think it wasn't? Any thoughts?
Opublikowany : 07/02/2023 2:44 am
Please show us your hotend/nozzle assembly from two different angles.
Opublikowany : 07/02/2023 8:26 am
RE: PLA Globbing and Burning
What Diem said, probably a leaking hot end. Also you should un-tweak what you have tweaked and start over with the default settings…
Opublikowany : 07/02/2023 2:46 pm
