Little layer gaps randomly in prints on both my MK3S & MK3S+
I have both a MK3S & MK3S+ along with a few Enders and for some reason both my MK3s give me these little layer gaps in my prints when printing them up vertically. I have used the Discord channel and made sure my Live Z was right so I don't think it's my Z and I can't seem to fix them where they can print a smooth vertical wall without the random little gaps. I've attached a few pictures of items.
RE: Little layer gaps randomly in prints on both my MK3S & MK3S+
Could those be where retractions are happening?
Possibly? Do you think I need to increase my retraction rate and test it or decrease it? Though looking at where they are don't most retractions happen no a layer change? those seem more randomly in the middle of the print
@greenhoe
I've seen gaps like that if I had retraction too high or I forgot and had PETG retraction settings(3-4mm) in my PLA print profile. I don't think PLA needs near that much. when it happened to me I saw gaps in places just like that.
@ssill2
Thank you, I will test the retraction settings and see if that helps!
@ssill2
Adjusting the retraction has helped a lot! Thank you.
@greenhoe
in my limited experience, I've found that I've not needed to depart from the prusa defaults at all for PLA. PETG is a different story. Every vendor's filament is it's own beast. Which is why I'm using up most of my different vendors and standardizing one 2 to 3 and getting those dialed in. To compound things, each model can present it's own challenges...
When I get a new filament I usually print one of these: https://www.thingiverse.com/thing:923097
It helps me get my settings dialed in and it adds to my luck, which I don't think you can ever have enough of!
@ssill2
how are your settings now?
