Layershifts printing tall slightly sloped parts
kreneskyp
(@kreneskyp)
I'm attempting to print a scale model of a rocket.  I keep getting layer shifts where the outer edge is printed slightly wider than it should be.  The layer shift is not biased to one direction.  It's a circular model and the entire layer is wider than it should be. This continues for about 5 layers and then it is back to the correct position.
The layer shifts occur in the same spot for the part, different heights for different parts.
I lubed and cleaned all axis but didn't help.
Publié : 27/06/2022 9:47 pm
blauzahn
(@blauzahn)
RE: Layershifts printing tall slightly sloped parts
Hello and welcome,
maybe you observe something similiar like the-benchy-hull-line.
Are changes visible in the slicer at those layers when you move the slider right of the sliced model down to those?
Publié : 27/06/2022 10:17 pm
kreneskyp
(@kreneskyp)
With the top section (top/first photo) there are two shifts.  First is a switch from gap fill to perimeter, then second is the opposite.
Publié : 27/06/2022 10:58 pm
blauzahn
(@blauzahn)
This thread might also apply to your problem:
mitigate-wall-bulge
Publié : 28/06/2022 5:27 am
kreneskyp
(@kreneskyp)
This appears to be the culprit. I adjusted perimeter width, perimeter speed, and enabled thin wall detection.  It didn't eliminate it entirely but close enough.
Thanks a lot!
Posted by: @blauzahn
mitigate-wall-bulge
Ce message a été modifié il y a 4 years par kreneskyp
Publié : 28/06/2022 11:19 pm
