Inconsistent output
Sannin
(@sannin)
Inconsistent output
Hello all. I built my printer a couple months ago and haven't had alot of time to play with it until recently. I am using the stock filament but I am having some inconsistent output. Using the stock file on the SD card I try printing the first layer of the Prusa Rectangle and what I get is the pictures below. Any advice would be appreciated.
Veröffentlicht : 30/05/2021 2:02 am
Mitglied
RE: Inconsistent output
I do not think you z-height or live Z is right.
Veröffentlicht : 30/05/2021 2:12 am
Sannin
(@sannin)
hmmm.. Am I too close to the bed cause I am not having any issues with bed adhesion?
Veröffentlicht : 30/05/2021 2:16 am
Sannin
(@sannin)
Too Low?
Veröffentlicht : 30/05/2021 2:24 am
Mitglied
That looks too high.  The corners are rounded and the loops in the rectangles look unfused.
Veröffentlicht : 30/05/2021 2:42 am
Sannin
(@sannin)
So I was at -1.705 and now this is what I get at -1.725. I guess I am just getting nervous I will scratch the bed. lol.
Veröffentlicht : 30/05/2021 3:29 am
Sannin
(@sannin)
-1.745      always seems to have some gapping on the left side of the print.
Diese r Beitrag wurde geändert Vor 4 years von Sannin
Veröffentlicht : 31/05/2021 2:46 am
Mitglied
That is either an extrusion issue or you are still not low enough.  I would lower it about 0.030 and try again.
Veröffentlicht : 31/05/2021 8:36 am
@sannin
Hi, are you using 7x7 mesh bed levelling?
available through the LCD screen?
have you tried "Life Adjust @Z@, My Way" by Jeff Jordan?
there are three test files in a zip file in the bottom of the first post, at the beginning of the thread
Veröffentlicht : 31/05/2021 8:38 am
Sannin
(@sannin)
@cwbullet yup was way to high. Thanks
@joantabb Havent touched the 7x7 at all. but that link you posted worked wonders. Thanks
-1.820 seemed to be my printers magic number. Now I know what to look for from now on.
Veröffentlicht : 02/06/2021 2:42 am
Dan Rogers
(@dan-rogers)
@sannin
It's a start - glad you got sorted.  You'll find you need to adjust live z when you change colors sometimes, when you change brands of filaments, or types of filament (material type).  There is  no magic z setting that will work in all situations.  Curly edges or lifting = too high, wavy like water usually means too low (too low will also accumulate material on the nozzle)
Veröffentlicht : 02/06/2021 1:59 pm
Sannin
(@sannin)
Guess I spoke too soon. Back to Back prints same settings.
Veröffentlicht : 05/06/2021 9:42 pm
Mitglied
I would guess you are still too high.  The only other thing that will do this is under extrusion.  I do not think it is the latter.
Veröffentlicht : 05/06/2021 9:46 pm
