How I print Small things ?!
Cycleman
(@cycleman)
Good morning guys
I want to print small things. Like the photo or a thin axis. When I print so,etching like that there is a big mess to my print. It prints And the filament is like a ball of yarn.
some advice?! I use to put the big surface in the bed. I also try to increase the bed temperature.only the first layer is on the bed the other is moving with the nozzle. I use pla.
thnx
Ce sujet a été modifié il y a 5 years 2 fois par Cycleman
Publié : 28/02/2021 10:13 am
Cycleman
(@cycleman)
RE: How I print Small things ?!
Οne more problem. In sign with letters it creates some dots/point for some reason.
any ideas?!
Publié : 28/02/2021 10:39 am
Clarmrrsn
(@clarmrrsn)
First issue sounds like first layer is not set correctly, follow this method then retry, I gather you have followed all setup procedures in tha manual?
Not sure about the second, some pictures would help please.
Ce message a été modifié il y a 5 years par Clarmrrsn
Tank you very much!
Publié : 28/02/2021 11:16 am
Clarmrrsn
(@clarmrrsn)
If larger objects print OK, and first layer is OK use a brim.
Tank you very much!
Publié : 28/02/2021 11:22 am
1 personnes ont aimé
Cycleman
(@cycleman)
@clarmrrsn
Thnx a lot. How much width mm is good for brim?!
Publié : 28/02/2021 6:31 pm
Posted by: @cycleman
I use 3-5mm for a brim. That part should print fine without a brim. Be sure your PEI print surface is well cleaned and that your Live-Z is adjusted properly. Are you using a smooth or textured print surface? What filament are you using?
Publié : 28/02/2021 10:11 pm
Cycleman
(@cycleman)
A very thanx. It works thanx!!!!
one more short question for extrusion. I got dots in a top layer. As I read there is overextrusion.
I go to prusa slic3r then filament settings and I change where it says extrusion multiplier to 0,8 just to try. But when I print I go to print menu then tune then flow and it says 100.is the same or not?!that is the difference?!how can I save the flow value from the printer menu.
thanx
Publié : 01/03/2021 7:39 am
Clarmrrsn
(@clarmrrsn)
@cycleman
Extrusion multiplier is explained here
https://help.prusa3d.com/en/article/extrusion-multiplier-calibration_2257
If you are still having an issue after this please post a photo and someone will assist.
Tank you very much!
Publié : 01/03/2021 7:50 am
