Curling Issue
3DLada
(@3dlada)
Curling Issue
Hi guys Iam having Lots of problem with curling small parts I allready Failed 6x times to print this file
https://fab365.net/items/321
my issue is with body part where there are small parts and they always end up curling and then the printre hiting those part out of print bed.
I really dont know what to do
So far I try This:
Chanze Zlive
Nylock mod done
tried blow cold air from outside onto printer 😀
also tried slow print speed 50%
Iam using yellow prusament
Publié : 26/06/2022 1:17 am
Membre
RE: Curling Issue
What type of filament and what setting are you using in slicer?
Publié : 26/06/2022 3:03 am
3DLada
(@3dlada)
RE: Curling Issue
Stock setting
Prusament pla yellow
.0.20 quality
Publié : 26/06/2022 3:05 am
Print in place mechanisms always require a near perfect first layer, you need a very clean bed and a precise first layer Z calibration.
Chanze Zlive
Please show us a first layer Z calbration print *on the print sheet*
Nylock mod done
This is very popular, I don't know why, it doesn't actually do anything useful as far as I can tell.
Cold drafts *cause* uneven cooling.  Protect the printer from drafts.
I would expect this to help a little ...
Concentrate on your first layer and the rest should be OK.
Publié : 26/06/2022 3:11 am
3DLada
(@3dlada)
RE: Curling Issue
I Done nylock because few ppl had problem with curling And that help. But not for me :/
Another fail i tried lower pla temp. And same result. Strange thing IS if i print that small part alone IT Will printed pefectly. But when i print all parts together then IT start failing
Publié : 26/06/2022 3:56 am
Swiss_Cheese
(@swiss_cheese)
RE: Curling Issue
Well, my drink of choice is Tequila, however even when I'm drinking I know that, Curling is generally caused by improper cooling, certain models need to have the filament temperatures, bed temperatures, and cooling balanced to prevent this, I'm going to post a link to a thread that may offer some helpful advice even though it's not specific to your troubles, it offers reasonable advice about cooling troubles.
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/how-to-improve-angled-overhang-prints-near-the-bed/
I think this might help you, if you have questions, just ask.
Good luck,
Swiss_Cheese
The Filament Whisperer
Publié : 26/06/2022 5:51 am
I have seen many claims but none that I believe.
Your first layer looks OK.
Two thoughts:
I've never seen a print-sheet wear in quite that manner, try another print-sheet.
@swiss_cheese is right, your cooling is somehow imbalanced.  Read the thread he linked.  Begin by protecting your machine from drafts and reduce the fan speed.
Publié : 26/06/2022 12:12 pm
Membre
RE: Curling Issue
Posted by: @mrvodkaaa
I saw folks claim the nylock mod are the cure for everything.  I have never done that mod and continue to have the bed as is and it works perfectly 99% of the time.
Publié : 26/06/2022 12:47 pm
RE: Curling Issue
Amen to that!
Publié : 26/06/2022 3:38 pm
3DLada
(@3dlada)
RE: Curling Issue
Another try another fail.
Also tried printing that small alone And no issue at all
Its Just failing when i try print all parts together
Publié : 26/06/2022 3:42 pm
AnnieR
(@annier)
RE: Curling Issue
My experience is that doing small pieces one at a time always works better than trying to do several at a time.
Publié : 26/06/2022 4:38 pm
3DLada
(@3dlada)
RE: Curling Issue
I prefer print all pieces one by one but this stl IS print in place so no chance :/
Publié : 26/06/2022 4:42 pm
Please show us the underside of a/some failed print(s)
Publié : 26/06/2022 9:44 pm
