Z movement on Unload Filament?
JMcK
 JMcK
(@jmck)
Hi!
I've been noticing this weird behavior through several firmware updates, and it's still happening in 3.12.2.
Basically, when I do certain things from the front panel menus "Unload Filament" being a good example, for some reason the Z-axis moves upward, maybe as much as 10-20mm. before unloading.
Is this intended behavior or is my (completely stock MK3) just weird this way?
When someone asks you if you're a god, you say, "YES!"
Publié : 29/05/2023 5:22 pm
Kronkie131
(@kronkie131)
RE: Z movement on Unload Filament?
yes this is intended it is so the nozzle isn't to close to te build plate and will form a blob destroying the nozzle
Publié : 29/05/2023 5:37 pm
JMcK
 JMcK
(@jmck)
I usually don't unload (or load) filament unless the Z is at least half-way up, so that didn't occur to me. Seems like a sane precaution though.
Publié : 29/05/2023 5:42 pm
Kronkie131
(@kronkie131)
Yeah me too but they’re some people that dumb af like look at some reviews on Prusa products like the powder coat pei people rate a 1 because they used pla and it didn’t stick and they probably didn’t use a new live adjust z or the amount of people that go to the forums with my print is not sticking and having they’re z offset at -0.040 so Prusa uses safety precautions in the most ways possible
Publié : 29/05/2023 6:09 pm
