Y-axis noise
The printer (Mk3S) started making noise in the Y-axis, mostly negative Y moves, a kind of chattering sound (I must be a car mechanic? LOL)
I can't see anything rubbing, belt tension seems fine. Any suggestions what to look for? I had just replaced the thermistor when the noise started
Veröffentlicht : 19/04/2022 10:17 pm
RE: Y-axis noise
I recently had to replace the Y Axis Bearing after about three years of regular use on my original MK3. It was making what I would call a scraping noise. When I removed the bearing, the ball bearings fell right out.
Veröffentlicht : 20/04/2022 1:47 pm
RE: Y-axis noise
That's as good an explanation as any! I'll give it a try, thanks!
Veröffentlicht : 20/04/2022 2:15 pm
