Y-axis noise
Jeff
 Jeff
(@jeff)
Y-axis noise
The printer (Mk3S) started making noise in the Y-axis, mostly negative Y moves, a kind of chattering sound (I must be a car mechanic?  LOL)
I can't see anything rubbing, belt tension seems fine.  Any suggestions what to look for?  I had just replaced the thermistor when the noise started
Napsal : 19/04/2022 10:17 pm
j1m1sh
(@j1m1sh)
RE: Y-axis noise
I recently had to replace the Y Axis Bearing after about three years of regular use on my original MK3.  It was making what I would call a scraping noise.  When I removed the bearing, the ball bearings fell right out.
Napsal : 20/04/2022 1:47 pm
Jeff
 Jeff
(@jeff)
RE: Y-axis noise
That's as good an explanation as any!  I'll give it a try, thanks!
Napsal : 20/04/2022 2:15 pm
