X layer shift, 7 consecutive failures
Victor S
(@victor-s)
Hello
I have a x layer shift, maybe Y layer shift also, is hard to say about Y.
I use Prusa I3 MK3S with the latest firmware.
I tried to print these 2 objects with 15% infill, PLA and PETG(all failed with x layer shift):
https://www.thingiverse.com/thing:1702891
https://www.thingiverse.com/thing:2120591
I don't think it is a hardware problem that I can fix, please take a look at the movie and say what do you think. Problem appears in the first 5 seconds and continues.
The printer simply goes right for no apparent reason.
I already read this article and I don't think it applies to what heappens here.
Thank you.
Best Answer by Dave Avery:
his problem is the object is printing in air because it's oriented in an unprintable orientation and he has supports turned off
Napsal : 07/09/2019 8:27 pm
Dave Avery
(@dave-avery)
RE: X layer shift, 7 consecutive failures
you are printing in the wrong orientation and without supports,  you need to rotate it sideways and turn on supports
Napsal : 07/09/2019 11:21 pm
That's a common issue when printing from a USB device that is unable to keep communications with the printer.
Try printing with the USB completely disconnected, and print the file from the SD card.
This post was modified před 7 years by --
Napsal : 08/09/2019 2:06 am
Dave Avery
(@dave-avery)
Napsal : 08/09/2019 3:55 am
Victor S
(@victor-s)
You are right, I should of enabled supports for this object.
Thank you.
Napsal : 08/09/2019 4:12 am
Dave Avery
(@dave-avery)
Napsal : 08/09/2019 4:21 am
1 lidem se líbí
rmm200
(@rmm200)
Make sure you check Z separation on supports. PrusaSlicer defaults to Soluble (.1mm). Set it to Removeable (.2mm). (I changed my defaults)
Otherwise - that thing will be a bear to clean up.
Napsal : 08/09/2019 3:19 pm
