X layer shift, 7 consecutive failures
Victor S
(@victor-s)
Hello
I have a x layer shift, maybe Y layer shift also, is hard to say about Y.
I use Prusa I3 MK3S with the latest firmware.
I tried to print these 2 objects with 15% infill, PLA and PETG(all failed with x layer shift):
https://www.thingiverse.com/thing:1702891
https://www.thingiverse.com/thing:2120591
I don't think it is a hardware problem that I can fix, please take a look at the movie and say what do you think. Problem appears in the first 5 seconds and continues.
The printer simply goes right for no apparent reason.
I already read this article and I don't think it applies to what heappens here.
Thank you.
Best Answer by Dave Avery:
his problem is the object is printing in air because it's oriented in an unprintable orientation and he has supports turned off
Publié : 07/09/2019 8:27 pm
Dave Avery
(@dave-avery)
RE: X layer shift, 7 consecutive failures
you are printing in the wrong orientation and without supports,  you need to rotate it sideways and turn on supports
Publié : 07/09/2019 11:21 pm
That's a common issue when printing from a USB device that is unable to keep communications with the printer.
Try printing with the USB completely disconnected, and print the file from the SD card.
Ce message a été modifié il y a 7 years par --
Publié : 08/09/2019 2:06 am
Dave Avery
(@dave-avery)
Publié : 08/09/2019 3:55 am
Victor S
(@victor-s)
You are right, I should of enabled supports for this object.
Thank you.
Publié : 08/09/2019 4:12 am
Dave Avery
(@dave-avery)
Publié : 08/09/2019 4:21 am
1 personnes ont aimé
rmm200
(@rmm200)
Make sure you check Z separation on supports. PrusaSlicer defaults to Soluble (.1mm). Set it to Removeable (.2mm). (I changed my defaults)
Otherwise - that thing will be a bear to clean up.
Publié : 08/09/2019 3:19 pm
