X-Axis Layer Shifts, My solution
Don't need any help, just writing this so future people can find it.
- I had X axis layer shifts randomly throughout my print when printing PETG.
- Higher bedtemp than PLA and in a vented enclosure, max temp 35C 95F so not too hot.
- Tightened the belts, lubricated everything, no solutions.
- Noticed that I was actually having the Y axis detect crashes multiple times per print.
- X axis would rehome after crashes, but due to zip tie placement would rehome at slightly different places, giving me X-Axis layer shifts.
- Y axis is lubed up, belts are tight, no mechanical problems.
- Turned off crash detection on the Y Axis and prints turned out great, no X-Axis layer shifting.
My theory: Something is wrong with the Y Axis crash detection that triggers when the bed gets too hot. (maybe the bearings bind a bit, or the control board gets hot from ambient... not sure) By just turning it off, I avoided the crash detection and re-homing which was giving me X-axis layer shifts.
Napsal : 02/09/2021 4:59 am
I've had crash detection turn off since forever, I found it to cause more issues than benefits.
Napsal : 02/09/2021 11:11 am
