        RE: Unscrew this bolt in right side of printer without taking everything apart.
I just assembled my printer today. My guess is that you would need to slide the x-axis up from the top, in order to reach that screw. And to do that, you would need to take off the extruder whose wires block you from sliding the x-axis up ...
                            Postato : 22/08/2020 7:48 am
                    Topic starter
 answered:
Yes, I just really don't want to do it. Assembling was very boring.
                            Postato : 22/08/2020 1:23 pm
Well, I'm afraid unless you can find an allen key or screwdriver that can reach in there you'll have to take some of the printer apart. It's quite a common thing to have to do with these types of printers.
As kayke said, you need to loosen up the Extruder assemble, remove the two Z-Axis top pieces and hand wind the X-Frame up to the top by turning both Z screws together.
                            Postato : 23/08/2020 1:04 am
