Unscrew this bolt in right side of printer without taking everything apart.
refunded
(@refunded)
I'd like to unscrew this bolt without taking everything apart and reassembling them. Is it possible?
Publié : 21/08/2020 8:23 pm
kayke
(@kayke)
RE: Unscrew this bolt in right side of printer without taking everything apart.
I just assembled my printer today. My guess is that you would need to slide the x-axis up from the top, in order to reach that screw. And to do that, you would need to take off the extruder whose wires block you from sliding the x-axis up ...
Publié : 22/08/2020 7:48 am
refunded
(@refunded)
Yes, I just really don't want to do it. Assembling was very boring.
Publié : 22/08/2020 1:23 pm
3Delight
(@3delight)
Modérateur Moderator
Well, I'm afraid unless you can find an allen key or screwdriver that can reach in there you'll have to take some of the printer apart.  It's quite a common thing to have to do with these types of printers.
As kayke said, you need to loosen up the Extruder assemble, remove the two Z-Axis top pieces and hand wind the X-Frame up to the top by turning both Z screws together.
Publié : 23/08/2020 1:04 am
