Test Print
Hanzilla
(@hanzilla)
Test Print
I’ve been trying to get my printer up and running, I haven’t had a successful print as of yet and was hoping someone would have some insight on my problem.
i have the original prusa i3 mk3s kit
assembly went fine, calibration went alright, but when I try to print the supplied test file from the sd (mk3s_PLA_Prusa_200..) I hit a problem at exactly 48% of the way through the print each time I attempt it (I tried slightly adjust the level with each print thinking maybe that was the issue, but no matter the level adjustment it can’t get past 48%). The left corner of the print begins to lift away from the bed and ends up detaching itself. Any common fix for this?
Napsal : 16/06/2020 4:32 am
Flo4Print
(@flo4print)
RE: Test Print
Hi, most of this kind of issue has the same causes : dirty bed or bad z offset. 1st clean the bed (in the sink like a plate) then check Z offset (probably too hight).
MK3S & Fusion 360
Napsal : 16/06/2020 5:41 pm
Hanzilla
(@hanzilla)
RE: Test Print
@flo-r
Thanks! I’ll be giving that a try. I’m currently trying to hunt down some IPA for cleaning. Every single store in my town is out of it but I got a lead on a shipment of it coming in at the end of the week, so hopefully that pans out :p
Napsal : 16/06/2020 10:19 pm
RE: Test Print
Try Dish Soap and water  while you wait, use a bed temp of 70C for PLA
Regards Joan
Napsal : 16/06/2020 10:41 pm
Hanzilla
(@hanzilla)
RE: Test Print
@joantabb
Will do, thank you for the tip! 🙂
Napsal : 16/06/2020 10:44 pm
