PrusaSlicer Import G-Code problem
Onur İnci
(@onur-inci)
Hi, i'm a new prusa user. I've installed PrusaSlicer but when i try to import g-codes that i downloaded from the internet i get this error. I've tried 2.1.0 beta as well but i get the same error. Anyone having this issue ?
Posted : 26/02/2020 3:14 pm
RE: PrusaSlicer Import G-Code problem
I believe you can replace the first line in the gcode file with one from PrusaSlicer. For more help, zip up a copy of a (small) gcode example you're having trouble with and upload it here.
Posted : 26/02/2020 3:39 pm
Onur İnci
(@onur-inci)
I tried that but didn't work :/. The files are yours actually. (Test_Prints_PLA) For example i want to try Calibration Cat from your files but i can't import it.
Posted : 26/02/2020 3:45 pm
Vojtěch Bubník
(@vojtech-bubnik)
Member Admin
@fernwehmind
You can only import config from G-code generated by PrusaSlicer or Slic3r-PE.
Posted : 26/02/2020 3:55 pm
Posted by: @fernwehmind
Ah, that's easy then. I've got my profiles in PrusaSlicer .ini format here. Where did you find those gcode files? I want to make sure I keep them all up to date.
Posted : 26/02/2020 4:13 pm
Onur İnci
(@onur-inci)
@bobstro
That's from this link: http://projects.ttlexceeded.com/3dprinting_live_z_calibration.html
Posted : 26/02/2020 4:16 pm
OK, thanks. Those are the Live-Z STLs. Use the profiles I linked to above to see the detailed profiles. Let me know if you have any issues.
Posted : 26/02/2020 4:44 pm
Onur İnci
(@onur-inci)
@bobstro
Thank you too. Your blog is awesome for the newbies like me. Thank you for the sharing your knowledge with us. Actually for quite some time i've been trying to make my printer usable. I have washed the sheet under the sink based on your blog. Then i've done some square calibration test with z live calibration. If you could check my other thread on forum and give me some advice based on my test screenshots i would be so appreciated.
I have some inconsistencies on my first layer. So if anyone who is experienced with prusa mk3s can help me on this that would be great!
Thank you again.
My other thread:
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/the-noise-coming-from-x-axis-and-first-layer-problem/#post-195645
This post was modified 4 years ago by Onur İnci
Posted : 26/02/2020 6:12 pm
