Prusa Slicer non-print moves speed displays wrong or produces wrong gcode
ga
 ga
(@ga)
If I turn on the speed display (View: Speed; Show: Travel) in Prusa Slicer, long distance non-print moves are displayed as 80 mm/s, which is the setting for infill; not 180 mm/s, which is the setting for non-print moves.  If I change the infill speed setting to 180 mm/s, it displays as 180 mm/s.  So the question is, is the setting just being displayed wrong, or is the gcode being produced wrong?
Publié : 21/10/2021 5:54 pm
Dan Rogers
(@dan-rogers)
Go to github and file the bug. If it is a bug, it will be good to get it recorded.
Be sure to provide a test case that shows the problem.
Publié : 21/10/2021 6:17 pm
ga
 ga
(@ga)
Issue #7148
Thanks, done, #7148
Publié : 21/10/2021 7:13 pm
ga
 ga
(@ga)
It's already fixed in 2.4
Looks like it's already fixed in 2.4.0
https://github.com/prusa3d/PrusaSlicer/issues/7148
Publié : 22/10/2021 3:00 am
