Nozzle disappeared!
Strange things have been going on at my place. Recently had x and y shifts on the same failed print, and today (two days later, with no printing since the failure), the nozzle is missing. Gone.
Opublikowany : 16/05/2019 4:29 pm
RE: Nozzle disappeared!
... Gremlins?
Opublikowany : 16/05/2019 4:45 pm
Whatever you did to your housemates ... well ... welcome to the fray.
Opublikowany : 16/05/2019 7:12 pm
Topic starter
answered:
Only thing that makes any sense is that the nozzle got caught up in a big glob, which I threw away. But I've searched my cardboard box of recycle plastic twice already, without finding the nozzle. Guess I'll go look again. Usually I have to heat the block a bit in order to get the nozzle out with a wrench, or socket, because I heat the block a bit before I tighten the joint between the nozzle and heat break.
Opublikowany : 16/05/2019 7:57 pm
