MKS3+ First layer failing to come out or coming out choppy
Ricardo Alves
(@ricardo-alves)
My printer started this issue where the first layer is coming out choppy/ with gaps looks like it fails to push the filament the first layer but not sure, this has started happening since the last firmware release recently 3.10.1-4697 I think, I tried already:
- Using a cleaning filament to clean the way to the nozzle (came out clean)
- Calibrated the first layer (comes out as seen on the screenshot)
- Tried slower speeds for first layer and nothing
- Tried every temperature variation from 210C to 220C (the result is the same even worse after 216C with loads of stringing)
- Removed the nozzle cleared the passage with a 2mm drill bit (and yes very carefully but no luck)
first layer choppy failed first layer print
The filament on the picture is a PLA+ which I have used before and had no issues.
I am struggling for days now trying to print basically anything, please help 😓
Este debate ha sido modificado el hace 4 years por Ricardo Alves
Respondido : 03/05/2022 4:52 pm
Ricardo Alves
(@ricardo-alves)
RE: MKS3+ First layer failing to come out or coming out choppy
Why cant I get this posted???
Respondido : 04/05/2022 1:08 pm
